i have a CEL that came with my new High flow catalytic converter
ok i have a 97 integra LS. i removed the OEM catalytic converter. i put in a new High flow cat. basically its a straight pipe. i put both O2 sensors back in the right spots. should i be getting a CEL??? im thinking its coming from the sensor with the new Cat. you guys think that might be it? if it is then im probably just gona throw my Oem cat back on.
Re: i have a CEL that came with my new High flow catalytic converter (cyang08)
ill assume you bought one from ebay for 25 bucks and thought it would work... no just throw the oem cat back on or buy a high flow it doest make that much of a diff unless your pushing some heavy power and ur state has no emissions
Re: i have a CEL that came with my new High flow catalytic converter (92DAIntegraXSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92DAIntegraXSI »</TD></TR><TR><TD CLASS="quote">ill assume you bought one from ebay for 25 bucks and thought it would work... no just throw the oem cat back on or buy a high flow it doest make that much of a diff unless your pushing some heavy power and ur state has no emissions</TD></TR></TABLE>
it is because of your secondary o2 sensor, it happened to my friend with his car when he put on a test pipe
you can get a simulator that plugs into the secondary o2, or convert to OBD1, but I would just put the stock cat back on, and call it a day
b18crx
01-14-2008 06:17 AM
already searched, cat, straight pipe, high flow, and gutted. any REAL answers on Catalytic Converter
FakeJDMEF8
12
01-18-2007 01:01 PM
