I BOUGHT ITR CAMS...I THINK I FOUND SKUNK2's in my car
Old 09-02-2005, 04:32 PM
loki_is_a_god's Avatar
Default I BOUGHT ITR CAMS...I THINK I FOUND SKUNK2's in my car
well heres the story...i bought a 2000 gsr last month...and i thought if i put some itr cams in her...she will be a little faster....so i bought them...when i took the cams out....they werent gsr cams...so i started to look around...for pics of cams i found some on here...they kinda of look like b17a cams...but then i found out that the intake cam has M and a 2 the exhaust cam has a M....theres a marking on the intake cam H01...but it looks like someone....scratched it on with a gun or by hand...i thought skunk2 cams said H008 can someone please help?
Old 09-02-2005, 06:33 PM
Default Re: I BOUGHT ITR CAMS...I THINK I FOUND SKUNK2's in my car (loki_is_a_god)
BUMP...because no one is helping me...just looking....
Old 09-02-2005, 06:45 PM
GDR888's Avatar
Any pics bro? It could really help
Old 09-02-2005, 07:43 PM
no they are in the car...i am putting trying to put belt back on....i can reach the tenisoner bolt.....is there a easier way...to put this belt back on...we got it on one time....last week...but the timing was off....we just cant put it back on....
Old 09-02-2005, 07:54 PM
AznMTboy's Avatar
hey if u bought ITR cam for ur GSR then you should try to return it, cus it wont help at all and it actually be even weaker. Because back then i was researching on them Skunk2 cam and came across how they were testing a GSR engine by putting an ITR cams and DYNO the before and after, and it was really a dissapointment.
Old 09-02-2005, 08:06 PM
skunkintegra's Avatar
Default Re: I BOUGHT ITR CAMS...I THINK I FOUND SKUNK2's in my car (AznMTboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznMTboy &raquo;</TD></TR><TR><TD CLASS="quote">hey if u bought ITR cam for ur GSR then you should try to return it, cus it wont help at all and it actually be even weaker. Because back then i was researching on them Skunk2 cam and came across how they were testing a GSR engine by putting an ITR cams and DYNO the before and after, and it was really a dissapointment.</TD></TR></TABLE>
heh.. thats funny to me.
i gained 16whp with the addition of ITR cams/header/hi-flow cat/v-afc
Old 09-02-2005, 08:20 PM
memicah's Avatar
Default Re: I BOUGHT ITR CAMS...I THINK I FOUND SKUNK2's in my car (skunkintegra)
heh, that is definately not true about the ITR cams. You will see gains. In fact, the cams in addition to the exhaust, are some of the few items that make that 15hp power difference.
*Edit* As for the belt install... Make sure you loosened the tensioner bolt enough... if its already loose, just work it down and to the right to make it easier. I found it easier to start the belt at the bottom and then move up; but whatever works for you.
Old 09-03-2005, 09:32 AM
vue_moua's Avatar
Default Re: I BOUGHT ITR CAMS...I THINK I FOUND SKUNK2's in my car (memicah)
dont you really just need a intake cam? from a ctr or itr
Old 09-03-2005, 09:45 AM
92integraVTECgsr's Avatar
Default Re: I BOUGHT ITR CAMS...I THINK I FOUND SKUNK2's in my car (vue_moua)
any info on just the ITR/CTR intake cam? I have an ITR intake cam and am still pondering whether to put it in or get in exhaust one too..
Old 09-03-2005, 12:29 PM
xx dc2teg xx's Avatar
Get both the intake and exhaust cam
ctr/itr are the exact same for certain years and for a couple years the ctr's were ever so slightly more aggressive so basically they're the same thing.
As for the above post about how itr cams are "weaker"- that is riduculous. Lift and duration are both more aggressive. If you just throw the cams in without any sort of tuning or parts, then yes-maybe you wont gain too much. Intake manifold with the cams will be a great combo.. Also look into or researc a vafc, fpr, fuel rail--and tuning
Old 09-04-2005, 08:33 PM
STAR
BMo Tuning's Avatar
ACTUALLY i had seen that article in i believe superstreet where tehy put in ITR cams and lost 3whp.... dont know how they did it , but they did. BUT if you read into it, they dyno'd on diff days and on different dynos, so that could be the whole difference right there.
Old 09-04-2005, 08:35 PM
STAR
BMo Tuning's Avatar
http://www.superstreetonline.com/howto/27398/
Old 09-05-2005, 01:07 AM
AznMTboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra &raquo;</TD></TR><TR><TD CLASS="quote">heh.. thats funny to me.
i gained 16whp with the addition of ITR cams/header/hi-flow cat/v-afc </TD></TR></TABLE>
really? then iono wat those guys, whose was testing smoking anyway.
Old 09-05-2005, 01:27 AM
allstockb18c's Avatar
Stick with the itr cams if your planning on keeping the compression stock, yes the skunks will yeild more hp if tuned thats no question about it, but if you look at dynos itr/ctr owns on midrange.
Old 09-05-2005, 03:02 AM
ALMXDUPINTEGRA's Avatar
I would choose the CTR cams over the ITR cams anyday
Old 09-05-2005, 06:47 AM
PDM
PDM's Avatar
Default Re: (ALMXDUPINTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALMXDUPINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">I would choose the CTR cams over the ITR cams anyday</TD></TR></TABLE>
why? the 00-01 ITR cams have almost if not identical specs as the CTR cams.
Old 09-05-2005, 08:36 AM
LSTEG96's Avatar
Default Re: (PDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PDM &raquo;</TD></TR><TR><TD CLASS="quote">
why? the 00-01 ITR cams have almost if not identical specs as the CTR cams.</TD></TR></TABLE>
CTR are StRaIgHt Up MaD TyTe JdM OnlY yO
Old 09-06-2005, 06:13 AM
STAR
BMo Tuning's Avatar
Default Re: (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">
CTR are StRaIgHt Up MaD TyTe JdM OnlY yO</TD></TR></TABLE>
HeLlLlLlLlL yEaH sOn! JdM OwNz JoO 4 lYfE!!!!
Are CTR any cheaper than ITR?? j/w dawg!
O yeah, get a skunk2 intake manifold and a type r or edelbrock throttle body too if your gonna get cams! Thatll really wake it up! w00t
Old 09-06-2005, 06:54 AM
I believe the CTR are a bit different. More HP too
Old 09-06-2005, 09:30 AM
Gqracer's Avatar
yeah those are skunk2 cams.. slap on some cam gears and adjust it
Old 09-06-2005, 02:00 PM
ptoledo's Avatar
yeah those are skunk cams, they use a dremil to mark the cams. I believe stage 1's if they say H1
marshall12395
03-06-2013 04:21 PM
azfab1031
04-16-2004 02:02 AM
lilxvtecxpwr
04-16-2004 01:12 AM
ULTRA911
11-06-2002 06:04 PM
ThugLife52
06-02-2002 10:13 PM
Quick Reply: I BOUGHT ITR CAMS...I THINK I FOUND SKUNK2's in my car
