How to Take Off the Transmission HELP ASAP!!!! im doing it right now!!!
my transmission will not slide off. I have all the bolts taken out.
what else needs to be taken out?
I just got the swap from HMO, so its outta the car and sitting here in the parking lot on the cherry picker..
i need help on how to take it off!!!
thanks
thanks
Daisy... Daisy...
Re: How to Take Off the Transmission HELP ASAP!!!! im doing it right now!!! (92integraVTECgsr)
Can I assume that you have removed the trannsmission mounts, axles, and shift linkage?
Re: How to Take Off the Transmission HELP ASAP!!!! im doing it right now!!! (Dogginator)
yes.. everything is removed.
I Just got the JDM B16 swap from HMO. So its not even in the car.
I wll remove the starter right now
Guess whos bizzack
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr »</TD></TR><TR><TD CLASS="quote">
oops, yes, that will help!!!
thanks soo much...i just got it off...you were some help...thanks aain!!!
Hype-R Stalker
Re: How to Take Off the Transmission HELP ASAP!!!! im doing it right now!!! (BOLO-FTW!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOLO-FTW!! »</TD></TR><TR><TD CLASS="quote">anytime </TD></TR></TABLE>
Did you just make a helpful post for once?
Guess whos bizzack
Re: How to Take Off the Transmission HELP ASAP!!!! im doing it right now!!! (FlatBlackTeg)
hahah ya, i was actually just about to link you, but of course your whoring *** found me
yes he did..
now how do i stop my flywheel from spinning? i need to loosen my crank bolt. im doing a timing belt change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr »</TD></TR><TR><TD CLASS="quote">yes he did..
now how do i stop my flywheel from spinning? i need to loosen my crank bolt. im doing a timing belt change.</TD></TR></TABLE>
Either jam a screw driver/piece of metal between the teeth and tranny, or use wire. Improvise.
Re: How to Take Off the Transmission HELP ASAP!!!! im doing it right now!!! (1990DA)
does it turn clockwise??? or counter clockwise???
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr »</TD></TR><TR><TD CLASS="quote">does it turn clockwise??? or counter clockwise???</TD></TR></TABLE>
Lawl.. I dunno, which way are you Turning it?
It's not reverse threaded if that's what you're trying to ask.
This is why people should look at DIY and helms before you start lol
hadehatch
05-11-2007 01:12 PM
LvN
08-31-2006 06:09 PM
