How to reset ecu?
Old Apr 13, 2002 | 10:30 AM
PolySquared's Avatar
Default How to reset ecu?
anybody know which fuse to remove in order to reset my ecu? My check engine light went up and I already know why.
Old Apr 13, 2002 | 10:41 AM
Isaac's Avatar
New User
Default Re: How to reset ecu? (PolySquared)
In the upper right corner, there are 2, I believe 7.5 Fuses and I think they are red. One is for the radio and the other is something else, but pull both of those and leave them out for about 5 minutes or so. Once your done (considering you don't know) let your car idle w/o touching ANYTHING! Wait until your radiator fan kicks on and turns off (more realistic air/heat/etc) to optimize the resetting.
Old Apr 13, 2002 | 06:20 PM
kkim's Avatar
fuse box in the engine compartment. 7.5 amp fuse marked "backup".
Old Apr 15, 2002 | 09:15 AM
Default Re: How to reset ecu? (kkim)
thanks a lot guys!
Old Apr 15, 2002 | 03:04 PM
mugenracer's Avatar
just disconnect the negative battery terminal
Old Apr 15, 2002 | 06:51 PM
araknis's Avatar
New User
Default Re: How to reset ecu? (mugenracer)
disconnecting the negative battery terminal is too much work for just resetting the ecu since you have to disconnect the positive one and then put on the positive on first and then the negative one. just pull the 7.5A backup fuse.. easy as pie..
zoom545
Mar 5, 2006 12:54 PM
9civic8
Apr 2, 2004 08:51 AM
WheAs MaI MojO
Jan 30, 2003 07:49 PM
VtecInteg95
Oct 27, 2002 09:06 PM
Spade
Jan 14, 2002 10:29 AM
