How to remove ECT sensor on DOHC VTEC head?
Old May 18, 2004 | 01:14 PM
Honda F1's Avatar
Default How to remove ECT sensor on DOHC VTEC head?
Trying to remove and replace with a new one but cannot figure out what socket to use. Any tips appreciated.
Old May 18, 2004 | 02:25 PM
Honda F1's Avatar
Default Re: How to remove ECT sensor on DOHC VTEC head? (Honda F1)
ttt
Old May 18, 2004 | 09:38 PM
Honda F1's Avatar
Anyone?
Old May 18, 2004 | 09:43 PM
IN VTEC's Avatar
I think it's a 17mm deep socket. You'll need to drain the coolant and possibly remove some other stuff that's in the way.
Edit: It might be a 19mm deep socket now that I think about it again.
Modified by IN VTEC at 9:10 AM 5/19/2004
Old May 19, 2004 | 08:12 AM
Honda F1's Avatar
Default Re: How to remove ECT sensor on DOHC VTEC head? (IN VTEC)
Cool thanks. You are talking about the one on the head right?
Old May 19, 2004 | 12:59 PM
AzG35's Avatar
I think the ECT sending unit on the head is either a 10mm or 12mm. The switch itself is a 17mm or 19mm
Modified by AzSi22 at 2:28 PM 5/19/2004
Old May 19, 2004 | 02:43 PM
IN VTEC's Avatar
There's actually three coolant thermosistors that use that info for three different purposes.
The 19mm ECT sensor in the head sends voltage to the ECU, and used for cold enrichment and temperature correction maps.
The 12mm ECT gauge sending unit sends voltage to the gauge cluster.
The whatever size it is fan thermoswitch is on the thermostat housing and it used to determine when to turn on the main fan. It's more of a mechanical actuator rather than a sensor, but it's still a thermosistor.
c4muzik
Aug 13, 2014 07:20 AM
kramer06
Jan 24, 2008 05:41 PM
teamvirus
11
Sep 1, 2006 03:05 PM
Honda F1
May 18, 2004 09:39 PM
