How to remove this
Old Dec 27, 2005 | 07:53 AM
PrinceAli132's Avatar
Default How to remove this
How do you remove that cap thingy in teh center. Thanks
Ali
Old Dec 27, 2005 | 07:55 AM
Integra Integra's Avatar
Default Re: How to remove this (PrinceAli132)
I think you need a puller from teh auto parts, adjust it to fit and pull out, thats how it was on a 1999 Mitsu montero good luck!
Old Dec 27, 2005 | 08:06 AM
Reid's Avatar
Global Moderator
Pry it off with a big screwdriver.
Old Dec 27, 2005 | 08:08 AM
Default Re: How to remove this (Reid)
Prying it off would work but be sure to spray some PB Blaster in order to break through the rust so it will be much easier to remove.
Old Dec 27, 2005 | 08:15 AM
Default Re: How to remove this (Integra Integra)
Thanks for the quick replies. So is it clamp on inside or what. How is it holding on.
Ali
Old Dec 27, 2005 | 08:57 AM
matto23's Avatar
edit - nevermind i miss read the post, i thought you wanted to remove the rotor
Old Dec 27, 2005 | 08:59 AM
Default Re: How to remove this (matto23)
i did that. ive been using a 8*1.25 bolt it worked fine in the front but not in the back. I read that you need to take the cap off and remove a nut.
Ali
Old Dec 27, 2005 | 09:05 AM
lVlemphizStylez's Avatar
what car is that on??? i know thats not an integra...the spindel nut that threads on to the axle is exposed on a teg
Old Dec 27, 2005 | 09:14 AM
Default Re: How to remove this (lVlemphizStylez)
Thats my 98ls
Ali
Old Dec 27, 2005 | 09:33 AM
SYTFU Tommy.'s Avatar
thats the rear. just use a hammer and tap the rotor all over to get it loosen
Old Dec 27, 2005 | 09:42 AM
sykotic's Avatar
Default Re: How to remove this (tngay)
if you can get a tiny flathead screw driver and try to hammer it into the wedge, otherwise you can get some pliers or vice grips around it and turn/pull till it comes out, its a pain in the *** but you can do it. Some of that PB blaster i think is what it's called would help, you normally use it on exhaust nuts/bolts, its called like a liquid hammer or somethin.
Old Dec 27, 2005 | 09:45 AM
Default Re: How to remove this (sykotic)
ah never had the need to remove the reaR rotor
Old Dec 27, 2005 | 09:48 AM
gsr dood's Avatar
that center peice is attached to the rotor. once those 2 screws are out ur rotor should be free....get a mallte and pound that sucker out.
Old Dec 27, 2005 | 12:19 PM
LSracing94's Avatar
Default Re: How to remove this (gsr dood)
agreed with above
Old Dec 27, 2005 | 09:04 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: How to remove this (LSracing94)
i dont remember having to take that off when i put on my brembo's (00LS)
Just need to take out the screw like you did and it should pull right off.
Old Dec 28, 2005 | 09:36 AM
NA_geezer96's Avatar
Default Re: How to remove this (00IntegrAllmotoR)
the center cap does not have to be removed to take off the rotor. however if you want to remove the cap, use a hammer and a small chisel. To remove the rotor soak the inner portion of the hat (around the center cap) with pb blaster. let it sit for a few minutes. now if you are replacing the rotors you can use a regular hammer to knock the rotors loose,if re-using rotors use a rubber mallet so you don't mangle the surface.
Old Dec 28, 2005 | 09:41 AM
SlamminS85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">what car is that on??? i know thats not an integra...the spindel nut that threads on to the axle is exposed on a teg</TD></TR></TABLE>
Yeah on the front end... it def looks like a honda.. and the rotor is not nearly big enough to be the front end of a teg or civic... so its a rear rotor for a teg
Old Dec 28, 2005 | 10:03 AM
Adam West's Avatar
Default Re: How to remove this (SlamminS85)
stick a flat head in the very tine creast and teap it off.. spray it down wiuth wd40 first... it aint as hard as it looks... good luck
Old Dec 28, 2005 | 11:12 AM
EB90RS's Avatar
that happened to me b4 and a chisel n hammer worked jus fine but like everyone else said you dont need to take the cap off if your just taking the rotors off
tobytigger
Nov 14, 2011 10:13 AM
street_ride14
Mar 21, 2006 05:02 AM
Polintan
Suspension & Brakes
Feb 20, 2006 05:51 PM
giff74
Mar 19, 2005 02:09 AM
Ubermensch
Jun 30, 2001 04:48 PM
