how much whp?
Old Apr 16, 2002 | 04:50 PM
spankaveli's Avatar
Default how much whp?
going dyno on the 20th, and just wondering what kinda numbers i'll be looking at
here are my mods:
stock intake pipe and filter
dc 4-1 header
2.25" test pipe
2.25" exhaust, straight thru hayame muffer
act xt00
18 degree timing
skunk2 intake manifold
b&m fpr
v-afc
someone said around 165 or so, but since my motor was kinda strong out of the box i'm thinking 170 or so. any ideas?
Old Apr 16, 2002 | 05:27 PM
B00ST2nR's Avatar
Default Re: how much whp? (spankaveli)
Same here...
I have I/H/E, ITR cams, VAFC. What numbers should I expect when I goto the Dyno and Tune it??
Old Apr 16, 2002 | 05:30 PM
dubster99's Avatar
Default Re: how much whp? (GS-R)
I would expect high 160's low 170's somewhere.
Old Apr 16, 2002 | 05:43 PM
Subtle's Avatar
Default Re: how much whp? (dubster99)
I agree...I have i/h/e/pulleys and my mechanic friend thinks I'm at about 160 whp on my GS-R.
Old Apr 16, 2002 | 06:04 PM
threatcon13's Avatar
New User
why dont you get an aem cai before going in for dyno.
Old Apr 16, 2002 | 08:18 PM
spankaveli's Avatar
Default Re: how much whp? (ALLMOTORDC2)
because i'm poor....ill probably dyno w/ the filter off, since thats how i run it at the track
Old Apr 16, 2002 | 08:56 PM
Spyderwebab's Avatar
165WHP Corrected TOPS! unless you've got one hell of a super tuner. You won't see a big increase, and not even huge then, until you do internal work(ie. cams and pistons). I increased 17whp with my signature over my first dyno of 158whp (I/IM/H/C/E and no tuning). I'll give you 7whp for the timing, testpipe, and VAFC.
Though I hope you prove me wrong. Good Luck, hope you come home happy
Old Apr 17, 2002 | 04:39 AM
Cone's Avatar
Do you have a chip for you Skunk2 IM? I don't know what all that will do to hp, but it modifies the ECU so it doesn't open the secondary intake runners now that you have a single stage manifold.
Old Apr 19, 2002 | 03:26 PM
spankaveli's Avatar
Default Re: how much whp? (Stealth 95 GS-R)
TTT
and no chip, not that it matters cuz the secondaries aren't there so it doesn't matter if the computer tries to activate them or not
Old Apr 21, 2002 | 06:55 PM
Cone's Avatar
it does more than just control the secondaries, it has new fuel/timing maps for the flow characheristics of the new IM, I belive. Check out http://www.hyperducktuning.com/ they have the Spoon ECU, and you get another free program (I'd go with the JUN) free, only $60 bucks for a kit to chip it yourself, but more if you send it to them. Check out the website for info. Plus, you get a raised rev limit, which would help when you add cams (Skunk2 Stage 2 ). With those you can get Portflow inner/ITR outer and retainer combo for only $320 and you'd have yourself a fast *** car.
-Andrew
GEN2 LS
K Series
Jul 25, 2014 04:21 PM
bmxkills
13
Apr 24, 2011 12:28 PM
anton_
Apr 21, 2007 03:07 PM
an2ny888
31
Jun 19, 2006 11:45 AM
h22aLSD
Dec 4, 2003 07:26 AM
