how much to lower?
Old Sep 27, 2006 | 07:13 PM
LSRracing95's Avatar
Default how much to lower?
i want to lower my car so the top of the tire is even with the top of the wheel well.
i will be running kyb agx all around with ground control coilovers on a 1995 acura integra ls.
what are the pros and cons to having the car lowered 3+ inches?
what parts could break or go bad or wear out faster?
thank you
--anyone with this setup, how low are you.. what did you do?
Old Sep 27, 2006 | 07:24 PM
Dartanian's Avatar
Default Re: how much to lower? (LSRracing95)
Pros:
Looks
Cons:
Minimal shock travel
Reduced handling characteristics
Most likely uncorrectable camber issues
Rubbing
The shocks probably can't handle a drop that low for very long
Stressed axle joints
I have Koni Yellows and GC's and I am only an inch lower than stock height. Function over form for me.
Old Sep 27, 2006 | 09:14 PM
GoldCoin's Avatar
everythign he said and ripped boots. this is mine 3 in the front 2.5 in the back. some call me crazy others call me slammed
i jsut slammed my car even more. now its 3.5 front 3 in the back. ill post up . but i got tein ss , skunk2 springs.
Old Sep 27, 2006 | 10:11 PM
ErMaK's Avatar
Default Re: how much to lower? (DC TWOin IT)
I have Tokico Illuminas shocks with Tein S-Tech springs. My car is about 2 inches lower all around. You do have to worry about scrape'n on alot of things and watch out for pot-holes, rail-road tracks etc....I have an Ingalls front & rear camber kit and I have virtually no wear on my tires and various suspension parts....I would think 3 would be fine, but the lower you go, the more likely you are are end the life of your shocks sooner.
Old Sep 28, 2006 | 01:14 PM
Default Re: how much to lower? (ErMaK)
i dont mind the rubbing, or really even the uneven treadwear from negative camber.
im really more concerned with:
-transmission components(differential)
-axles breaking, boots cracking open
-gas mileage? would lowering your car any amount affect gas mileage for the worse?
im planning on aligning the car tomorrow, a full 4 wheel alignment..
and once i save the cash, im looking for front and rear camber kits.
should/would anything change besides having negative camber, such as toe(in/out), caster.
i have the kyb agx setting on 1-softest up front and 2-second softest in the rear..
and the ground control coils are all the way down for now.. im thinking of raising the front coils up 3/8" and the rear coils up 1/2"..
my car seems to have decreased gas mileage and it seems to drive uneasy, or wobbly around 35mph to about 60mph and then its smooth again.. lowering/alignment issue?
im really looking for someone who knows alot about suspension and lowering, etc. because i need this problem solved.
helpppp! thanks guys
feel free to post pics of your ride and your setups.. im interested and pics of mine will be up when the car is more complete.. and aligned, etc haha
Old Sep 28, 2006 | 01:18 PM
1999CivicSi's Avatar
3" in front
little less than 3" in back
skunk2 full coilovers
Modified by 1999CivicSi at 3:42 PM 9/28/2006
Old Sep 28, 2006 | 01:46 PM
-Championship-'s Avatar
76.169.175.137
Default Re: how much to lower? (1999CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">3" in front
why would the rear be lowered than the front
nice car by the way, except the rims
Old Sep 28, 2006 | 02:37 PM
escape2me's Avatar
</TD></TR></TABLE>Thats 3 inches? Looks like stock...
Old Sep 28, 2006 | 02:42 PM
its 3 inches..i dont think it looks close to stock at all..go look at a stock teggy
Old Sep 28, 2006 | 02:46 PM
Default Re: (1999CivicSi)
thats definitely not stock height.. doesnt appear like its 3 inches.. if so i think mine is about 5 1/2 lol...
butttt... i really need some useful information here and if possible, answers to my long assss previous post..
please help!! thanks
Old Sep 28, 2006 | 02:52 PM
SilentHill's Avatar
Default Re: (LSRracing95)
dont buy a rear camber kit just use washers, and dont ask how to use washers to adjust camber do a search.
Old Sep 28, 2006 | 02:57 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: (SilentHill)
its amazing once you are really low how crappy the ride feels. Sometimes I go almost all the way down, and then i go up just a little bit(1/2) inch, it feels so much better with more shock travel. Also, you may mess up your axles faster, as well as the inside of your tires from bad camber
Old Sep 28, 2006 | 03:01 PM
the_unknown's Avatar
GDD Lonely Krew
ok ill try to answer some of your questions. transmissions have nothing to do with lowering your car so dont worry about that. axles and boots however are now probably not at the optimum angle and could get worn out prematurely. just remember though that plenty of people run slammed (including me) and have no problems. treadwear really isnt even an issue if your toe setting is correct, camber has little to do with uneven treadwear. oh and about gas mileage, the only way i could see lowering your car causing bad gas mileage is if your alignment is that far off. the alignment should take care of your uneasy feeling between 30-65mph as well. hope this helped
Old Sep 28, 2006 | 03:18 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">its 3 inches..i dont think it looks close to stock at all..go look at a stock teggy</TD></TR></TABLE>
That does not look like a 3" drop. Measure from the center of the wheel to the fender and post that. Stock height is 14" in the front, 14.25" in the rear.
Old Sep 28, 2006 | 05:28 PM
Default Re: (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">
That does not look like a 3" drop. Measure from the center of the wheel to the fender and post that. Stock height is 14" in the front, 14.25" in the rear.</TD></TR></TABLE>
front is a little more than 11..like 11 1/4 rear is really close to 11
Old Sep 28, 2006 | 07:51 PM
night time bumpppppp
EdWord
Jul 11, 2009 12:11 AM
em1woot
Suspension & Brakes
Nov 4, 2007 05:20 AM
RGoose18
Suspension & Brakes
May 5, 2006 10:15 AM
soundcheck187
Jul 5, 2005 12:56 PM
bretx0r
May 27, 2002 03:42 PM
