How much compression should a cold engine generate?
Old Oct 27, 2013 | 01:24 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default How much compression should a cold engine generate?
Well thats basically the question in askin ha.
I am going to pull the engine out of my Acura and replace it. I'm going to test compression on another b18. But it'll be out of the car because I don't wanna install it and it not work. So what's the right number to have with a cold engine?
Thanks
Old Oct 27, 2013 | 01:33 PM
Shit Posts: 15
10 Year Member
Default Re: How much compression should a cold engine generate?
I looked it up on google and all I found was stuff for boats haha
It's a 95 integra. Will be using a b18.
Old Oct 27, 2013 | 01:52 PM
fcm's Avatar
fcm
Old Fart
As long as it is not real low, [not below 140psi] it is more important that all four are about the same, [no more then 28psi diff.], a wet test should be done also.
A leak down test will tell you more. 94
Old Oct 27, 2013 | 01:57 PM
Shit Posts: 15
10 Year Member
So even during a cold test they psi should not be before 140?
And by wet you mean dropping oil into the cylinder right?
Last time I did this. My tester got full of oil.
Old Oct 27, 2013 | 01:58 PM
racebum's Avatar
variance will be higher cold and numbers are lower. one of my type r's that had 260psi hot read about 220psi cold. i got in the habit of rigging up starters to jdm engines before i installed them to double check compression and make sure it was the same as the importer stated.
Old Oct 27, 2013 | 02:01 PM
B_Swapped93's Avatar
link on how to do this ? i'm swapping engines currently.
Old Oct 27, 2013 | 02:35 PM
Shit Posts: 15
10 Year Member
I usually just slap the transmission on, put 2. Bolts to mate it and put the starter on to turn the engine over.
I think with the right amount of washers on the starter/block surface, you can rig the starter to the flywheel with no trans.
But back to your type r. So basically about 40 psi lower while cold than when hot?
Old Nov 2, 2013 | 07:18 PM
Shit Posts: 15
10 Year Member
Okay.
I started up my engine that was knocking. Let it warm up. And did a compression test.
I had the same 90-95 psi of compression through all 4 cylinders.
This engine has new piston rings which I installed and I also rehoned the walls myself(700 miles on everything)
Should I just change the bearings And leave the pistons alone?
It is the compression so low that I should just ditch the engine?
Old Nov 14, 2013 | 10:02 PM
Shit Posts: 15
10 Year Member
I am backs other results!
I believe they are good. Just want some re assurance.
Tested engine compression.
Cyl 1-3 got 130 psi
Cyl 4 got 100
Did valve lash adjustment
Cyl 1-3 got 150 psi
Cup 4 got 120 psi.
Such a difference. But the car will run right?
I put the compression tester and cyl4 and removed the Gauge and plugged an air compressor hose and I held cyl 4 at tdc
And couldn't hear much air escaping?!?
But insight on those psi numbers please. And thanks n
Old Nov 15, 2013 | 06:09 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Originally Posted by JDMswagSerf
Cyl 1-3 got 150 psi
Cup 4 got 120 psi.
I would pull the pan off and check the bearing on that rod.
You could have a spun bearing, bent valve, or bad rings in that cylinder.
Old Nov 15, 2013 | 06:52 AM
Ditch it ! lol 130 is below the "service limit".
Old Nov 15, 2013 | 11:41 AM
Shit Posts: 15
10 Year Member
I'll remove the pan today.
And these numbers are on a cold engine. They go up once installed and warmed up right?
If I put cyl 4(low comp cup) at TDc with the valves closed and I put compressed air in it. I should be able to hear that leak right
Old Nov 15, 2013 | 12:40 PM
Hype-R Stalker
If you spin it by hand, can you hear any slop/clunk in that cylinder?
A spun/worn bearing will change your comp on that cylinder even if the rings are good.
Old Nov 18, 2013 | 01:14 AM
Shit Posts: 15
10 Year Member
When I turn the engine over. It turns over easily! No clunks or noises
Haven't pulled the pan off, been burried in hw!
I can check for leaks by having the piston at tdc and valves closed and blow I blowing compressed air into the engine with the compression tester hose right?
Old Nov 18, 2013 | 08:38 AM
Drive Slow's Avatar
Test #4 again then add a little oil into the cylinder and test again. If the number goes up, your rings are bad.
r.etheridge
Feb 12, 2011 05:31 PM
skaternak
10
Aug 9, 2009 05:48 PM
spidermancivic
Jul 13, 2005 07:53 PM
98R-1144
Jan 6, 2003 09:50 PM
