How much boost can a
Old Nov 14, 2001 | 11:12 AM
teg92's Avatar
Default How much boost can a
Stock LS bottom end with 60k on it handle? I am planning on staying NA with no vtec but something inside of me sparked and made me want to calculate piecing together a turbo kit. However when all is said and done custom or kit it's a crap of money including low comp pistons & shotpeened rods & arp bolts etc.
Would the stock bottom end be fine with a tuned (A/F, ignition wise) 5-7lbs? How much hp would 5-7lb give on a nonvtec honda. Thanks
Old Nov 14, 2001 | 11:17 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: How much boost can a (teg92)
Ask the FI forum. Need to know what fuel system, fuel management, what turbo specs, etc.
Old Nov 14, 2001 | 11:24 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: How much boost can a (Dave-ROR)
6-7lbs would be safe. Run a compression test and leakdown prior to boost install, too.
Ryan
Old Nov 14, 2001 | 11:46 AM
b00st-0wnz's Avatar
Default Re: How much boost can a (vtecvoodoo)
vtec: so 6-7psi would be safe with a T60?
sorry man, but you can't say "6-7psi would be safe." without knowing the actual specs of the turbo, fuel setup, etc, etc.
Old Nov 14, 2001 | 11:50 AM
Tomakit's Avatar
Most aftermarket kits will run you $3k for the turbo/piping/fuel system...
figure another 500 for a clutch, installed...
install on the turbo will vary...if you can do the labor, all the better.
if your LS has compression numbers better than 170, id say go for it.
with the above mentioned stuff, you could run 7 lbs daily for a long time.
Tom
(H-T im me if you have any other questions)
cityofcaterpillars
Engine Management and Tuning
Feb 13, 2017 04:02 PM
EF9RacerWhoa!
Mar 22, 2009 08:31 AM
RuKKus
Jul 21, 2002 06:49 PM
teg92
Nov 16, 2001 03:04 PM
