high compression turbo
Old Apr 18, 2003 | 03:50 PM
EF9RacerWhoa!'s Avatar
Default high compression turbo
I plan on doing a high compression turbo setup with a b18c5. for the most part..i know the pros and cons of doing such. but as there are pros and cons to doing anything. BUt i just have a few questions so i know where im going
1. how much boost and you put on the stock c5 sleeves
2. whats good boost to put on the stock pistons ( this is just for now until i can upgrade )
3. what kinda fuel management am i looking at? upgraded fuel pump / FPR / and fuel rail?
4. and help me out with anything else i would be needed to run the car daily. other than some quality tuning
Old Apr 18, 2003 | 04:24 PM
b16ahybrid's Avatar
Default Re: high compression turbo (EF9RacerWhoa!)
Not sure how much boost the sleeves can handle but probably at least 15psi.
You'll need hondata or better for tuning.....
I'd say about 11psi with good tuning...(stock)...
Old Apr 18, 2003 | 04:26 PM
Pelican's Avatar
I'd ask itr206.
But its all just a balance.
Learn all you can. The archives are your best friend
Old Apr 18, 2003 | 04:37 PM
Default Re: high compression turbo (Pelican)
i learned a lot from searching...just not exactly what i needed to know
Old Apr 18, 2003 | 06:37 PM
MiraiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9RacerWhoa! &raquo;</TD></TR><TR><TD CLASS="quote">I plan on doing a high compression turbo setup with a b18c5. for the most part..i know the pros and cons of doing such. but as there are pros and cons to doing anything. BUt i just have a few questions so i know where im going
4. and help me out with anything else i would be needed to run the car daily. other than some quality tuning</TD></TR></TABLE>
Don't do it on stock pistons...get forged at the very least!!
Old Apr 18, 2003 | 11:38 PM
*Boostwerks*'s Avatar
1. 1-20. It all depends on tuning, and a little bit of luck.
2. It really depends on the size of the turbo, but I wouldn't push more then 6psi with a moderatly sized T3/TO4E.
3. I would do a Hondata setup. get a walbro 255lph and 450cc, and leave everything else
4. Don't half *** ANYTHING. Take your time, and use only the best parts.
Old Mar 22, 2009 | 03:41 AM
N I T R O's Avatar
I RUN this setup and it was cool
Old Mar 22, 2009 | 08:31 AM
TheShodan's Avatar
Moderator
Why in the world would one bring back a 6yr thread? Kill this already..
henchie
Mar 28, 2016 07:20 AM
monster_c
Apr 6, 2012 02:14 PM
RTst92
Mar 5, 2006 01:56 PM
gtconcepts
Dec 19, 2002 06:11 PM
Charlie Moua
Nov 8, 2002 05:08 AM
