How low to go?
Old Feb 12, 2003 | 10:32 AM
Xscream's Avatar
Default How low to go?
Okay, long story short. I threw on coil overs but forgot to get the factory ride hieght from the ground to the frame or sideskirts (how ever you would prefer to messure it). Anyone know what it is?
Also what is the hieghts that people like to drop to? Right now I have it at 1 finger between the fender well and the tire but want to go lower once summer hits. I have some Blue's on order so I will not be running the facotry shocks. What are the popular drop ammounts (facotry alloys) w/o having any major problems?
Old Feb 12, 2003 | 11:07 AM
emr88's Avatar
Default Re: How low to go? (Xscream)
Anything more than a 2" drop and you're going to be running into major negative camber, scraping speedbumps, poor handling, etc. If you can afford new tires every few months for that 'dumped' look, go for it!
Otherwise, stay conservative or look into getting camber kits.
Off the top of my head, I would stay stock height from floor to the jack points (on the sides of the car) is about 6.75-7".
Old Feb 12, 2003 | 11:30 AM
PM-Performance's Avatar
Default Re: How low to go? (emr88)
thats bullshit . i have ridden on my other teg with 3+ inch drop for like ever and never had unnormal tire wear and get this . . . . never aloigned and no camber kits,
my type R i was slammed over 2.5 prolly 3 inches or so and never had camber probs again and no tire wear and never realigned, i only got camber kits becuase i get em for free. so why not take em . . . integras take drops very good though.
dont believe the hype man /
Old Feb 12, 2003 | 11:36 AM
fivespeedintegra's Avatar
Default Re: How low to go? (itr206)
two of my friends had civics with 2.5"+ drops and no camber correction....their tires were worn to the threads on the inner edge within 3 months. so believe the hype. the amount of wear is also going to depend on how soft your tires are. both of my friends were using Z-rated tires which tend to wear fast anyways.
there's my $.02....take it or leave it
Old Feb 12, 2003 | 11:52 AM
Default Re: How low to go? (fivespeedintegra)
nope, now your talking about diff cars. . . civics its verty common to wear on almost any drop ,. mosty in the rear , becuase. . . . linked rear susp
Old Feb 12, 2003 | 11:57 AM
i stand corrected....but i have to say the wear was just as bad up front.
Old Feb 12, 2003 | 12:56 PM
emr88's Avatar
Different cars? Which civic? 5th gen shares the same suspension design as the 3rd gen Integra, very similar cars. 6th is very similar as well.
What I said is overly generalized, but I do know that a 2.25" drop (Neuspeed Race Spring for example) will yield approximately -2 degree negative camber on a 3rd gen Integra (front). Thats enough to wear the inner tire tread faster then the outer, regardless of tire brand, rating.
Either way, run whatever you want, just realize that too much negative camber *might* eat up the insides of your tire and will do little for street performance.
[Modified by emr88, 1:57 PM 2/12/2003]
Old Feb 12, 2003 | 01:55 PM
that's what i thought....same chassis
Old Feb 12, 2003 | 02:39 PM
[HrZn]4life's Avatar
In general it is better not to go beyond 2 inches, especially if you are on stock dampers. There are exceptions though; my car was dropped for 3 years at about 2.25 and I had barely any camber wear. But the troubles that you run into when being too low are not worth it.
Old Feb 12, 2003 | 03:24 PM
743 Stunna's Avatar
Default Re: How low to go? ([HrZn]4life)
i would go for about 1.5 thats like the perfect ride hieght
Old Feb 12, 2003 | 03:41 PM
Hairy Gorilla's Avatar
Default Re: How low to go? (743motorsport)
Drop it to what looks nice. I'm riding on Neuspeed Race and lovin it. No alignment or camber kit yet...Tires looking good too
Old Feb 12, 2003 | 03:45 PM
brotherton16's Avatar
my 90 integra is dropped about 2 inches and there is no visible camber problem and no tire wear....i also have a 88 accord(first car) that is slammed like 3.5-4 inches and it looks like everthing is about to brake up front but no problem in the rear. it has been that way for about 9 months and i bottom out on everything and it suxs....but for some reason there is no inner tire wear?????????? it is noticable if i go around doing burnouts or somethin though....just normal driving and no prob
~J
93 Eg Couper
Suspension & Brakes
May 4, 2009 06:54 AM
SoyMilk
Suspension & Brakes
Mar 19, 2007 12:19 AM
fdjizm
21
Feb 19, 2007 01:59 PM
blurrrcivic94
May 5, 2004 06:59 AM
bleeedawg
Oct 30, 2003 11:48 AM
