How to: Install ASR subframe brace and ITR sway bar on DC2 Integra
Old 03-05-2013, 03:19 AM
  #76
NemesisCBR's Avatar
Default Re: How to: Install ASR subframe brace and ITR sway bar on DC2 Integra
Going to say thanks for the write up since i used it to install my 24mm asr bar and brace. I went with asr's recommendation drilling out both holes instead. I was missing my 3/8" bit and had one a size or two smaller and it was sufficient to drill out the threads for the bolts i had. I also had to recheck/tighten the allen bolts that hold the brace to the bracket when i tightened the other bolts. My final install result was a vertical endlink on the pass side, mostly vertical endlink on driver and the bar itself was mostly horizontal. With the bar arm curvature im not sure whats perfectly horizontal anyway but the endlinks are just about all the way shortened already.
Regarding the endlinks, i emailed asr about using the stock endlinks over the adjustable ones because of the people complaining about eventual squeak/noise and Charleston assured me they dont squeak (3 years on his dd) and that the oem endlink cannot be used. He said rsx type s endlinks can be used instead which look similar to that SI endlink but probably has proper length. So far no squeaks on the asr spherical endlinks but i do get the occassional clank however im not sure if thats the rta with the worn bushing more notably heard with the extra stiffening or the movement of the spherical endlink as the bar twists. At this point its an acceptable amount but i will opt for another option if it gets annoying.
Old 03-05-2013, 05:46 AM
  #77
GagnarTheUnruly's Avatar
Good info, and nice looking setup
Old 03-30-2013, 09:24 PM
  #78
PURPLERANGER's Avatar
Im on my final leg of this project and Im wondering, do I need to replace the inner LCA bushings when I remove the LCA bolt?? I would rather not have to pay extra if its not needed, but if I do, I might just buy new LCAs.
Old 03-30-2013, 10:49 PM
  #79
Only if you wind up cutting out the bolt (because it's bonded to the bushing and won't unscrew). If you can get the bolt out fine you can reuse the bushing, unless of course it's totally shot.
Old 04-03-2013, 07:27 PM
  #80
hnjbjp5's Avatar
Good stuff.. Thanks
Old 08-01-2013, 07:35 PM
  #81
DC4PB's Avatar
Old 02-11-2014, 12:28 AM
  #82
B_Swapped93's Avatar
Glad this write up was here ! I'd like to ad a little bit of a suggestion, while this was an issue with aftermarket LCA's(I'm using F7's) it may not be for everyone I could barley get my hands/wrench around the lower nut that secures the backing plate. I have small hands too so I undid the lca to strut and bent it down made things a lot easier. On the driver's side my integra has a plastic guard that goes around the tube from the gas fill neck to the tank I had to remove it again to get a wrench in easier will be using the ASR 32mm hollow bar on the car now .
Old 02-11-2014, 02:58 AM
  #83
safedriver's Avatar
As noted in the "ASR Instruction Integra" guide, on page 3.
I had to go there to figure out what you did, about the LCA removal, to get my wrench into that small opening.
http://www.passwordjdm.com/Install_N...race_DC_EG.pdf
Old 02-07-2019, 05:42 PM
  #84
dave7's Avatar
Thank you to the OP for posting this guide!! It was by far the best guide that I found searching online. I was able to successfully install the asr frame brace and jdm itr bar on my gsr today. Guides like this help me to learn valuable mechanic skills haha.
Old 02-07-2019, 07:15 PM
  #85
wunfstgsr's Avatar
Is a alignment needed after this install?
Old 02-08-2019, 04:01 AM
  #86
361 accord's Avatar
I was just checking this out last night because I was wondering how to re-route the ABS wire.
ASR now has V1.5 LCAs (the triangular holes go all the way through) but the end link holes are in the middle like most others.
I haven't received them yet, but, wouldn't it be an equal sin to lower the car 2-3" from stock on stock control arms and end links? the bar would be unnaturally angled up. so if you had a lowered ride height and ASR/blox, LCAS it would rotate the sway bar back down to horizontal as it should be, right?
just thinking, adjustable end links would solve any problems that came up, just sucks its another $100 for the metal sway bar collars and decent end links.
Old 02-08-2019, 07:22 AM
  #87
dave7's Avatar
^My gsr has 5 lug from ctr and abs. So the abs lines wouldn't fit under the asr brace like they should. So I just zip tied them on the front side of the subframe and it seems fine.
Old 02-08-2019, 07:34 AM
  #88
dave7's Avatar
I also used a size smaller, 5/16" and it worked just fine. That 3/8" must be a typo in the OP because it would be completely unnecessary and way too big. I only drilled the top hole out and it was just fine.
Old 02-11-2019, 05:11 AM
  #89
PatrickGSR94's Avatar
I use Function7 LCA's with correct sway bar end link placement, no issues after 10+ years with them, and 15+ years with an ITR rear sway bar. I routed my ABS lines in between the shock fork and the LCA and zip tied them to the LCA.
  #90
No, suspension geometry is not affected when installing a subframe brace or sway bar.
Old 02-11-2019, 05:49 AM
  #91
aw614's Avatar
The only thing I can see possibly losing alignment is when you have to pull the rear control arms off and then reinstall it. It feels like my alignment changed very slightly when had to reinstall the control arms. And yes I did tighten at ride height
Old 02-11-2019, 05:50 AM
  #92
Unless there's a ton of play in the bushings or enlarged holes or something, alignment shouldn't change any appreciable amount. But it's never a bad thing to get it checked and adjusted anyway.
icucnme
01-28-2010 02:42 PM
nxstrikerxn
Suspension & Brakes
04-02-2005 09:57 PM
dgdarien
10
03-30-2003 01:09 PM
InTeGrA_bLazEd
12-20-2002 04:00 PM
mamaboy
12-05-2001 09:07 PM
Quick Reply: How to: Install ASR subframe brace and ITR sway bar on DC2 Integra
