how important is the O2 sensor
Old May 27, 2002 | 12:18 PM
integra*RS*'s Avatar
New User
Default how important is the O2 sensor
I have a 94 and i believe i have the same stock 02 sensor .
Should I change it? What would be the benefits of changing it? Need help because i don't wanna change it if i dont have to, it's kinda expensive.
Old May 27, 2002 | 12:33 PM
eastsidemags's Avatar
Default Re: how important is the O2 sensor (integra*RS*)
your car will benefit nothing.
if it aint broke...
Old May 27, 2002 | 12:46 PM
Cosworth's Avatar
Are you throwing CEL (Check Engine Light)? If you don't get any CEL, then don't worry about change it. However, if you're throwing a CEL due to an O2 sensor, then you should change it as soon as your pocket will allow it.
The O2 sensor basically let your engine achieve stoichiometric (sp?) air:fuel ratio by "sniffing" the exhaust gas. If it is broken, you could run lean or rich, depending on the problem with the clogged/faulty O2 sensor. (And, many times you won't pass emissions.)
To put it simply, your engine won't run at an optimal A:F condition which is .
Hope that helps.
Old May 27, 2002 | 01:53 PM
New User
Default Re: how important is the O2 sensor (Cosworth)
thanks for the replies
Whats the probability of my o2 sensor not working to its full potential?
it's the original one from 94.
Because I cut the o2 wires a year ago (i was changin my header) and the check engine light didn't even go on. I rewired them back and it was fine. I was just curious because my mpg is not as good as it should be. Less than 300 but close per full tank of gas.
Old May 27, 2002 | 02:01 PM
94GsRacer's Avatar
i have a 94 GSR also and my O2 sensor went bad and i had to change it. If your not getting the CEL light, then dont bother to mess with it until it does.
Old May 27, 2002 | 02:07 PM
New User
Default Re: how important is the O2 sensor (94GsRacer)
.....ok.....i'll probably leave it alone
thanks for the posts
8083tcman
Dec 31, 2008 12:55 AM
notAdiesel
Aug 12, 2008 11:19 AM
ken2830
Feb 1, 2008 12:09 AM
CivicDXRaceCar
May 30, 2005 05:59 AM
anothersickhatch
May 15, 2004 10:22 PM
