how do you fix a P1337 code??
Old Mar 24, 2005 | 06:00 PM
KillaB18's Avatar
Default how do you fix a P1337 code??
failed smog and got a p1337 code. i have a 98 integra with a b20 in it. the code is for Engine Speed (RPM) Fluctuation Sensor No Signal.
where is this located and what can i do to fix this problem
Old Mar 24, 2005 | 08:27 PM
KillaB18's Avatar
Default Re: how do you fix a P1337 code?? (KillaB18)
anyone know??? where the sensor is located??
Old Mar 28, 2005 | 01:14 PM
KillaB18's Avatar
no one knows.????
Old Mar 28, 2005 | 01:17 PM
SuzukaBlueAP2's Avatar
Default Re: (KillaB18)
p1337 in the 98-01 Service manual reads:
"no signal in the crankshaft speed flucuation sensor circuit."
This sensor is mounted on the oil pump. What year is the B20 from? If it doesn't not have this sensor, or the sensor is bad, you will throw this code.
Old Mar 28, 2005 | 03:21 PM
KillaB18's Avatar
its a b20b from a 98 i believe. is there any way i can get the code out of there if i dont have the sensor
Old Mar 29, 2005 | 07:26 AM
Well, resetting the ECu will clear the code for now. But, if the sensor is not there and it should be, or there is a fault in the circuit, it will come back eventually. give it a try, see what happens.
Chris_Bye
Feb 19, 2005 05:27 PM
