How do you disconnect the e-brake thru the rear trailer arm
How do you disconnect the e-brake thru the rear trailer arm?
I pushed the rubber cover piece back to find a 12mm nut it alrdy is loose and continues to spin.. can someone advise as how to seperate the line so i can replace the trailing arm?
Re: How do you disconnect the e-brake thru the rear trailer arm (BlueIntegraBoy)
theres a big square a little after the ebrake, i dont think it dissconnects there?
i do see their is a 12 mm nut but it just spins on me so even if i disconnect it from the caliper does that nut go left loosey or does it just spin
jash
16
07-12-2010 03:55 AM
racekar
02-25-2009 09:46 AM
