how do I up the compression
Old Jul 23, 2003 | 05:30 AM
tommy b's Avatar
Default how do I up the compression
i heard that pistons and cams are a good way to up my compression. If so, what type of pistons/cams should i be looking for? Is there anything else i can do in addition to that? Thanks for any help.
Old Jul 23, 2003 | 06:08 AM
redlinegsr's Avatar
Default Re: how do I up the compression (tommy b)
change your head gasket...have your head milled. You can gain quite a bit doing thoset wo things without having to touch the internals (i.e. pistons)
Old Jul 23, 2003 | 06:16 AM
Try2Live4God's Avatar
Well I would change the pistons and camshafts. Depending on the type of car you have, i'm sure there are JDM versions. They're usually better than the USDM one's. I'm looking to go all motor and pistons and camshafts are definitely on my list for mods.
Old Jul 23, 2003 | 07:32 AM
opi's Avatar
opi
Default Re: how do I up the compression (redlinegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr &raquo;</TD></TR><TR><TD CLASS="quote">change your head gasket...have your head milled. You can gain quite a bit doing thoset wo things without having to touch the internals (i.e. pistons)</TD></TR></TABLE>
like he said, thinner head gasket or having the head milled can raise your compression aside from swapping out the internals/pistons...just depends on how high you want to go...BTW, what motor are you planning on using?
Old Jul 23, 2003 | 07:45 AM
arw321's Avatar
Default Re: how do I up the compression (Try2Live4God)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Try2Live4God &raquo;</TD></TR><TR><TD CLASS="quote">i'm sure there are JDM versions. They're usually better than the USDM one's. </TD></TR></TABLE>
lol^^^
I wouldn't recomend head milling to increase your C/R by a LOT. (ie more than 1 point).
Head milling throws off cam timing.
Do it right, and get yourself some high compression pistons.
Adam
Old Jul 23, 2003 | 07:56 AM
P1mpSlap's Avatar
If you change your piston to deck ratio, and run more agressive cams. You will not have adequite valve clearence pending certain cams. Not to mention your head and block must be milled perfectly otherwise a 1 layer head gasket will not form a good seal.
There is no other way to up the compression, other than to swap some ITR or CTR piston in there. Do no mill the head or block unless you never plan on running pump gas again with the CTR pistons. Also you wont be able to run agressive cams (Skunk stage 2s, Toda Spec B, C, etc.. ).
I recommend, CTR pistons for the 12: 1 compression and Toda Spec Cs
Old Jul 23, 2003 | 11:13 AM
Furuoka's Avatar
How the hell do you up compression with cams? Come on guys use the search button it works great.
Old Jul 25, 2003 | 02:00 PM
Default Re: (Furuoka)
You up the compression with cams by getting cams that have a higher lift. In case you don't know, Lift is the height that the valve is lifted off of the valve seat. Usually the more lift within reason, the better as the higher the valve is lifted and the more flow that can go past it.
Old Jul 25, 2003 | 02:36 PM
mr.beeks's Avatar
Default Re: how do I up the compression (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">
by decking the block and milling the head sure does raise compresion
but dont spect for the rest to remain the same.
cams get their timming retarded and have to be properly adjusted if not the
engine overheats.
as well that valves could impact piston
the safe way like he says get higher compression pistons and thats a given easy task.
and the rest should be easy..
Old Jul 25, 2003 | 02:56 PM
KingFish's Avatar
Default Re: (Try2Live4God)
You can't up the compression by adding cams. The cams just leave the valves open or closed longer to let more fuel into the combustion chamber.
Old Jul 25, 2003 | 02:58 PM
KingFish's Avatar
Milling the head and block can up your compession, but if you really want to raise it I would suggest pistons. I think for every compression point you raise it you will get about 7-10 horswpower.
Old Jul 29, 2003 | 10:26 AM
B16Anees's Avatar
Default Re: how do I up the compression (erictegra)
12:1 Compression with Civic Type R Pistons? Whaaaaaaattttttt????
Old Jul 29, 2003 | 10:35 AM
TeamTooQuick's Avatar
Default Re: how do I up the compression (B16Anees)
Mill your head, thinner head gasket, CTR or Weisco(sp?) pistons, and some Skunk 2 Stage 2's....IMO..
Old Jul 29, 2003 | 11:03 AM
redlinegsr's Avatar
Default Re: how do I up the compression (TeamTooQuick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick &raquo;</TD></TR><TR><TD CLASS="quote">Mill your head, thinner head gasket, CTR or Weisco(sp?) pistons, and some Skunk 2 Stage 2's....IMO.. </TD></TR></TABLE>
Thank you.....there are all kinds of detrimental aspect that can be done to your engine to screw it up but as long as it is done properley wheather it is milling the head, pistons or what ever you feel the need you should have nothing to worry about
Old Jul 29, 2003 | 11:27 AM
EL Vap133's Avatar
have your combustion chambers welded...
Old Jul 29, 2003 | 11:44 AM
cw98typer's Avatar
Default Re: how do I up the compression (Vap133)
CTR pistons and a 1 or 2 layer head gasket. That will definatley jump it up enough and still be a reliable daily driver.
Old Jul 29, 2003 | 12:41 PM
THC EK LSVTEC's Avatar
jun 3 cams and jdm itr pistons or je pistons
The Up Garage
11
Apr 8, 2006 12:32 PM
canada-civic
Mar 1, 2006 07:50 AM
trooper0641
12
May 10, 2004 09:41 PM
allmotorgsrekk
Jan 17, 2004 11:18 PM
Killer_B
May 29, 2003 07:03 PM
