Can i tap a new sandwich adapter on the oem adapter?
Old 05-04-2005, 10:57 AM
DC2TT's Avatar
Default Can i tap a new sandwich adapter on the oem adapter?
Ok i need to know this, i wanted to use an aftermarket oil cooler from setrab,so i went on to buy sandwich adapter .When i want to tap my sandwich adapter only i find out that i have so call an oil cooler on whcih running with coolant apparently,my question is since i have an oil cooler and i comes originally with adpater ,can i tap my new sandwich adapter on the original one?
and can i run after market oil cooler with the coolant oil cooler as well? or i need to remove the old cooler and only use the aftermarket cooler? the old cooler is something that run some hose to some water pipes.
What should i do if i want to run aftermarket oil coole can i take out the hoses to water pipe and tap it to my after market oil cooler? again i have searched and find it usefull if someone can provide some tech
R-Toyz.com
04-04-2007 05:34 PM
DC2TT
05-10-2005 07:56 AM
Dan GSR
15
02-04-2004 02:11 PM
blykins
07-25-2003 09:59 AM
T-sohctec
04-21-2003 04:36 AM
Quick Reply: Can i tap a new sandwich adapter on the oem adapter?
