Changing Timing Belt...List of Parts?
Old 11-02-2005, 07:03 AM
S2KILLA's Avatar
Location: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Changing Timing Belt...List of Parts?
Like the topic states, I am in dire need of a timing belt and water pump change. I think I have pretty much most of the parts and wanted to know what was definitely needed and what was a good idea to replace.
Timing Belt
Water Pump
Water Pump Gasket
Cam Seals
Crank Seal
Valve Cover Gasket
Spark Plug Well Seals
Valve Cover Grommets
Timing Belt Tentioner
Did I miss anything? Thanks for the help.
Old 11-02-2005, 08:45 AM
S2KILLA's Avatar
Default Re: Changing Timing Belt...List of Parts? (SupersonicBlueGSR)
little help here?
Old 11-02-2005, 08:50 AM
not so JDM Dan's Avatar
sounds all good, i would do a valve adjustment while your in there and replace tune-up stuff like fuel filter and plug wires if not replaced allready
Old 11-02-2005, 09:04 AM
98 Spec R's Avatar
Honda Bond
Old 11-02-2005, 09:08 AM
Racermech's Avatar
all 3 standard belts, you have to take them off anyways, might as well replace them
Old 11-02-2005, 09:09 AM
jthm's Avatar
Tensioner.
Old 11-02-2005, 10:18 AM
S2KILLA's Avatar
Default Re: (squee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">all 3 standard belts, you have to take them off anyways, might as well replace them</TD></TR></TABLE>
as in...?
Old 11-02-2005, 10:24 AM
S2KILLA's Avatar
Also, I was looking at these kits on ebay...
http://cgi.ebay.com/ebaymotors...wItem
Should I get the first one and get the VALVE COVER GASKET, SPARK PLUG WELL SEALS, VALVE COVER GROMMETS seperately or get the second one and get the tentioner seperately...?
Old 11-02-2005, 04:28 PM
Default Re: (SupersonicBlueGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">as in...?</TD></TR></TABLE>
power steering, ac and alternater, Racermech has a great point
Old 11-02-2005, 04:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">Also, I was looking at these kits on ebay...
Should I get the first one and get the VALVE COVER GASKET, SPARK PLUG WELL SEALS, VALVE COVER GROMMETS seperately or get the second one and get the tentioner seperately...?</TD></TR></TABLE>
personally i would go all OEM HONDA but thats just me, whatever floats your boat, i def dont cheap out on that sorta thing
Old 11-02-2005, 05:18 PM
Racermech's Avatar
Default Re: Changing Timing Belt...List of Parts? (JDMDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDan &raquo;</TD></TR><TR><TD CLASS="quote">power steering, ac and alternater, Racermech has a great point </TD></TR></TABLE>
Thank you thank you......bow and walks off stage.
I would also stick with OEM for the seals and the timing belt. I went for a bosch water pump and it has been fine. I also went for jsut normal accessory belts.
Old 11-02-2005, 05:19 PM
Default Re: Changing Timing Belt...List of Parts? (Racermech)
Old 11-03-2005, 04:26 AM
S2KILLA's Avatar
i can just get those at like autoazone or advanced auto parts, right?
Old 11-03-2005, 05:30 AM
Racermech's Avatar
That is what I did, you need the alternator, AC and PS belts. They are about $5 each
Old 11-03-2005, 06:01 AM
S2KILLA's Avatar
word up man, yeah I might as well spend the extra 20 bux and have that comfort noing that theyre new. I wanted to take it to the track one time before the season closed but that doesnt look like its happening
Old 11-03-2005, 07:59 PM
KingElli's Avatar
Dude just buy the OEM Kit and be done with it. Considering you dont know what you need to actually do a timing change i'd prolly go to a professional .
Old 11-04-2005, 05:21 AM
S2KILLA's Avatar
Default Re: Changing Timing Belt...List of Parts? (KingElli)
DuDe...Ok Bro...I am going to have it done by a professional. But If I get the parts for half of what he buys them for I will save that much more money. I know math is a hard concept for some people, either that or they **** out money. My friend is a mechanic and he does all my stuff. I watch and learn and he gets paid...not a lot but I do appreciate his time and effort. He said he would do it for around $200 bux, which beats 800 from the dealer. /thread
Old 11-04-2005, 02:02 PM
Kito96LS's Avatar
200 bucks!!!is that ur homie???..damn...OEM parts, everything u mentioned is bout closed to 300...u also need coolant....thats about a total of 500 bucks!!!....jus buy ur homie food n beer!!!hahahahaaa...dont go cheap!!!!if u do..u'll pay more down the road!
Old 11-04-2005, 03:38 PM
Default Re: Changing Timing Belt...List of Parts? (Kito96LS)
werd
Old 11-04-2005, 05:18 PM
KP9
KP9's Avatar
I'm pretty sure the 200 bucks was intended as the "labor" only
"Hints this whole thread is about him making sure he has bought all the gaskets and belts and parts........ that should be tended to when the mechanic goes in for the job....."
TOO MUCH TORQUE
04-18-2011 06:27 AM
rhino87
04-08-2009 11:26 AM
cbmprelude
09-02-2005 07:39 PM
ninerpilot
08-16-2005 07:44 AM
Quick Reply: Changing Timing Belt...List of Parts?
