horn doesnt work
Old Nov 8, 2005 | 07:04 AM
2ndGenREX's Avatar
Default horn doesnt work
hey i have a 91 acura integra gs. The horn doesnt work at all. I changed teh fuse under the hood and still not working... I was wondering what my next step should be?? I'm planning on taking a look at the horn itself but i was wondering how to get at it. I kno its on the bumper but does the whole bumper have to come off in order to change it?
Old Nov 8, 2005 | 07:27 AM
Deluzional's Avatar
Default Re: horn doesnt work (2ndGenREX)
Try to check the horn connections as well, mine use to have a lot of play and come loose quite often
Old Nov 8, 2005 | 07:47 AM
JDM-EJ1's Avatar
Default Re: horn doesnt work (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">Try to check the horn connections as well, mine use to have a lot of play and come loose quite often</TD></TR></TABLE>
Exactly. And check the horn itself to make sure it's still good.
Old Nov 8, 2005 | 08:01 AM
2ndGenREX's Avatar
does the whole bumper have to come off to take a look at the horn?? any short cuts there?
Old Nov 8, 2005 | 08:18 AM
JDM-EJ1's Avatar
Default Re: (2ndGenREX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndGenREX &raquo;</TD></TR><TR><TD CLASS="quote">does the whole bumper have to come off to take a look at the horn?? any short cuts there?</TD></TR></TABLE>
On my EJ1 it does. Well, it doens't need to, but it makes things a whole lot easier. I would just remove it, things will be a lot easier that way.
Old Nov 8, 2005 | 12:16 PM
int3gra07's Avatar
* B A N N E D *
I have a g2 as well. Is your steering wheel stock? It'll be easier to check your steering wheel first before you take out your bumper.
Take your steering wheel out and see if that plastic black ring has all its leads and if there in good condition.
Old Nov 8, 2005 | 12:37 PM
JDM-EJ1's Avatar
Default Re: (int3gra07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra07 &raquo;</TD></TR><TR><TD CLASS="quote"> Take your steering wheel out and see if that plastic black ring has all its leads and if there in good condition. </TD></TR></TABLE>
Old Nov 8, 2005 | 12:38 PM
projectTeG's Avatar
check your ground boxes in the front. i had a problem with my horn and lights and my ground connections were krusty.
Old Nov 8, 2005 | 02:00 PM
doh240's Avatar
Default Re: (projectTeG)
since you're gonna fix the horn,
time to upgrade your horn, to something that'll blast
imo, stock horns are kinda weak
and get a horn that plays mariachi music, lol
Old Nov 8, 2005 | 02:30 PM
del sol1658's Avatar
Default Re: (doh240)
Just use your finger
Old Nov 8, 2005 | 02:53 PM
2ndGenREX's Avatar
k....kinda new with this whole tryin to take apart my horn......So far i got as far as taking out that screw that holds the horn acura piece on......but i cant get the horn piece off it like still connected but cant see from where?? let me guess i gota take apart the dash to get this fukin thing out?? omg it driving me nuts lol....somebody fill me in on how to take this horn out
Old Nov 8, 2005 | 03:25 PM
Desired_Speeds's Avatar
when i removed my horn cuz it fried, I stuck my hand in there w/ a 10mm wrech and slowly unscrewed it, it took like 5 mins for my
Old Nov 9, 2005 | 06:04 AM
int3gra07's Avatar
* B A N N E D *
ARe you trying to remove the steering wheel? No you do not have to remove the dashboard. ONce you removed the acura piece cover out, you need to unscrew the bolt thats in the middle. YOu see it? ONce you unscrewed it out hit me up I'll tell you what to do next.
Yes I'm a noob but I took my wheel out alot.
Old Nov 9, 2005 | 07:53 AM
PLAGUED_DB7's Avatar
Just grab your **** and yell.
Check your steering wheel...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra07 &raquo;</TD></TR><TR><TD CLASS="quote">ARe you trying to remove the steering wheel? No you do not have to remove the dashboard. ONce you removed the acura piece cover out, you need to unscrew the bolt thats in the middle. YOu see it? ONce you unscrewed it out hit me up I'll tell you what to do next.
Yes I'm a noob but I took my wheel out alot. </TD></TR></TABLE>
Old Nov 9, 2005 | 07:56 AM
HONDA RR's Avatar
Check the wiring because the horn doesn't just go out like that.
Old Nov 9, 2005 | 09:09 AM
2ndGenREX's Avatar
i just picked up this teg, i never had this horn working...... i only got one screw out on the acura cover piece......it still seems to be connect from somewhere?? does it snap in/out? it looks like its held on by another screw/bolt but i cant locate it
Old Nov 9, 2005 | 09:40 AM
int3gra07's Avatar
* B A N N E D *
huh? no Its just one nut, and after you take out the nut, slip out the wheel and disconnect the wires. thats it its off.
hungdat89
Apr 18, 2007 05:20 PM
MINTGRN4DR
Oct 5, 2006 10:32 AM
drifter_for_life06
Jul 26, 2005 11:05 PM
cwestin'39
Nov 21, 2003 02:50 AM
FBP Si 2000
14
Dec 23, 2001 07:54 PM
