high idle
Old Dec 27, 2007 | 07:44 PM
TegGsr4dr's Avatar
Default high idle
my cousin put in jdm itr pistons at a shop and when he got it all it does is idles at 2..like when he is driving its fine the before a stop he puts it in nutrual then it idles back at 2...so everytime its not goin its idle'n at 2...maybe he has a vacuum leak or sumthing?? what u guys think it is?
Old Dec 27, 2007 | 07:50 PM
Rickdrizzle's Avatar
wow, same thing happened to me. it always idles at 2k. when i lightly tap on the gas while its at 2k, it drops and then comes back up to 2k.
i still haven't got the problem fixed yet, so i can't tell you what it is. i also changed the iacv. have your cousin tried changing it yet?
Old Dec 27, 2007 | 07:51 PM
Schister66's Avatar
Man U FTW
check for vaccuum leaks...somewhere there is air passing by the throttle.
Old Dec 27, 2007 | 07:57 PM
TegGsr4dr's Avatar
no he hasnt tried changin that yet
Old Dec 28, 2007 | 04:24 PM
smoggy08's Avatar
Default Re: high idle (TegGsr4dr)
CAN YOU HEAR ANY VACCUM LEAKS????? CHECK YOUR GAS CABLE IT MIGHT NEED ADJUSTMENTS!
Old Dec 29, 2007 | 01:05 AM
northemt88's Avatar
Check to see if your throttle cable is to tight then check you idler screw. if not that dizzy timing?
Old Dec 29, 2007 | 02:53 PM
God-Driven's Avatar
check for vaccum leaks with WD40 I dont recomend brake cleaner or throattle body cleaner since is higly flamable, did he use a new intake manifold gasket? also check timing just like the other guys recomended.
Old Dec 29, 2007 | 04:43 PM
TegGsr4dr's Avatar
timing is fine...he put new headgasket and new intake maifold gasket..maybe the people who put it in did something wrong..cuz he also got a b16a with CTR piston and its fine..idle is normal and everything..
crxnonvtec
22
Sep 3, 2009 02:52 PM
EJuno
Jan 29, 2008 06:23 PM
tomy_r
Jan 12, 2006 06:34 AM
89b16hf
Feb 17, 2004 07:31 PM
crx-si
10
Jan 30, 2003 07:26 AM
