To high of compression?
Old Nov 17, 2005 | 05:41 PM
oilguzzler's Avatar
Default To high of compression?
Hey i was just wondering if 12.5:1 compression is ok with my stock gsr? i know that stock compression is 10:1 if im not mistaken and i would probably have to run 91 oct. to eh? would i notice th edifference or just get 9.8:1 or 9:1 compression pistons?
Old Nov 17, 2005 | 05:48 PM
4dr_all_day's Avatar
Default Re: To high of compression? (oilguzzler)
if you want to go boost drop the comp a little... all motor bump up the comp... if you do go 12.5:1 93 and up oct is what you need to run if im not mistaken... if i were you and i had the money i would go boost... lots faster with the right parts and tuning...
Old Nov 17, 2005 | 05:49 PM
95TegSE's Avatar
With 12.5:1 compression and only 91 octane you'd need a hell of a tune. Also you'd be undercammed with a stock top end. 9:1 or 9.8:1 pistons would cause you to lose power if you're not going the FI route.
Old Nov 17, 2005 | 05:55 PM
Default Re: To high of compression? (95TegSE)
^ agreed
Old Nov 17, 2005 | 07:50 PM
oilguzzler's Avatar
Default Re: To high of compression? (4dr_all_day)
so with 12.5:1 with the stock engine, would i notice the difference? If so how big about? like 5 horsepower if that?
Old Nov 17, 2005 | 07:52 PM
gsrious's Avatar
max hp is not from what compression you are running, but how good the tune is.
peakboosth22
Jun 20, 2006 08:55 AM
jdm2teg
Dec 14, 2005 01:41 PM
Quade
Apr 5, 2005 03:12 PM
immortal
Nov 6, 2001 08:05 AM
BLaCKWiDoWSi
Nov 2, 2001 03:12 PM
