Hesitation
Old Sep 10, 2014 | 08:22 AM
cruzthestreets's Avatar
Default Hesitation
I have a 1990 integra. After about 20 minutes of driving, it seems like it doesn't want to accelerate in 1st & 2nd gear. Is there anyway to fix this?
Old Sep 10, 2014 | 07:22 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Re: Hesitation
theres always a way to fix damn near anything, just depends on how much you're willing to put into it to fix it.
check your cam and ignition timing. make sure your cam gears are lined up properly, sometimes they will slip and be off a tooth on the timing belt. i'd recommend picking up a timing light, and two 5mm pin punches.
Here's an article that gives an idea on what I'm talking about. See the first pic:
Timing belt installation procedures on 1994-2001 Acura B18 Series engines - Engine Builder Magazine
And heres a link for some pin punches: (these will make replacing a timing belt a lot easier, BTW)
MAYHEW Pilot Punch, Black, 5mm Tip, 3/8 x 4-1/2 in - G5158562 at Zoro
Old Sep 14, 2014 | 07:48 AM
thanks! i got it all done yesterday and now shes running better than ever
Old Sep 17, 2014 | 11:01 AM
wunfstgsr's Avatar
Loved
Community Favorite
So how did you fix your problem?
OP making threads like this asking for help then replying i fixed it and not saying what you did makes no sense! This helps others to not make the same thread and flood the forums.
Civicman86
Jun 24, 2006 07:12 AM
baonest1
Feb 24, 2003 03:37 PM
carcala
Jan 18, 2003 04:06 PM
3rdGteg
Oct 31, 2002 09:58 PM
keebler65
Mar 31, 2002 12:24 PM
