help with turbo setup
Old Apr 6, 2007 | 06:27 PM
johnls's Avatar
Default help with turbo setup
ok here is my setup
jdm b16a
stock b16 heads with gsr cams
stock bottom end
dsm injectors,bov
3 piping and dp
38mm wastegate
the trubo i thinks is a T04E but the numbers are 63 hot side and 60 cold side
not sure on what to get tuned on was think of s100 but don't know
let me know what you think will that trubo be good for 300 horsepower
Old Apr 6, 2007 | 07:21 PM
nate_2k5's Avatar
Default Re: help with turbo setup (johnls)
s100 doesn't have a boost option that i know of so you will have to use either a s200 or 300 if you want to stay hondata or you can opt for uberdata or crome which are free.
opt for a 50 or 57 trim t3/t4 rather than a full on t04e that turbo is too big for your goals and the size of the engine if you want quick spool up
Old Apr 6, 2007 | 07:42 PM
johnls's Avatar
Default Re: help with turbo setup (nate_2k5)
what power do you think i can make
Old Apr 6, 2007 | 09:23 PM
nate_2k5's Avatar
that i could not tell you right off the top of my head. i am more familiar with b18's, but witha 57 trim on that motor i'd say 350-375 is achievable, whether you should turn up boost that high is another...make some goals, decide if you are going all stock motor then ask what size turbo is needed for your goals
Old Apr 7, 2007 | 01:23 AM
boosted96teg's Avatar
just letting u know s100 does have a option for boost. When i bought mine a year an a half ago the s100 was 295 and the boost option was n extra 200.
Old Apr 7, 2007 | 03:26 AM
johnls's Avatar
Default Re: help with turbo setup (boosted96teg)
what kind of power would i make with the turbo i have now
Old Apr 7, 2007 | 10:31 AM
nate_2k5's Avatar
go into the civic forums, not many ppl boost b16 on integras
chewyv
Dec 24, 2009 10:32 PM
GSROWNSU
Jun 13, 2008 02:01 PM
EKhybrid
Sep 9, 2005 10:19 PM
hondaaccord94
Mar 26, 2005 03:05 PM
