Help! Timing!
Old Nov 28, 2005 | 06:10 AM
oilguzzler's Avatar
Default Help! Timing!
Hey all, i just reassembled my head and everything and think i moved both the cams over a tooth from stock(like how they are supposed to be at tdc, i think there clockwise a tooth) and i started it. so now my main concern is if haveing the cams off by a tooth will teh pistons hit the valves? it runs but has a very low idle and is very sluggish like it has no compression or something. I think i need to readjust the valves. But ya help anyone!?
Old Nov 28, 2005 | 06:19 AM
mmuller's Avatar
Mad Scientist
Default Re: Help! Timing! (oilguzzler)
mmm, so why are you running the car with cam timing a tooth off?
Old Nov 28, 2005 | 08:06 AM
oilguzzler's Avatar
im not on purpose, just wondering if i did not line it up properly if that would damage the valves. Would the car run if the cams were off by one?
racebum
Nov 7, 2008 10:18 AM
mr_magoo
Aug 23, 2008 12:41 AM
Powered by VTEC
Jan 25, 2008 10:13 AM
crxowner
May 16, 2007 07:20 PM
blowme
May 17, 2005 04:48 PM
