HELP! tail light problem!!!
Old Sep 12, 2002 | 09:54 AM
AH Tow EX's Avatar
Default HELP! tail light problem!!!
okay, to make a long long story short.
i forgot to plug in my turn signal bulbs into my lens after i painted them. so i just rested them in the splash guard. that was fine, until i hit a curb.
this collision moved my front bumper cover out of place and along with that the splash guard. so that meant the bulbs were dragging on the ground.
they popped and eventually the whole wire harness broke off. so now all i have left is some wire.
well i was driving down the freeway when this happened and my interior lights turned off. the only thing that was on was my radio lights and my clock. my headlights were still on, but my tail lights and everything else was off.
i need to know what to do to fix this problem, i have a feeling it's rooted in the turn signal problem. but any help would be GREATLY appreciated! TIA!!!!!!!!!!!!!
the run down...
tail lights don't work
front turn signals don't work
gauge lights won't work
Old Sep 12, 2002 | 09:56 AM
AH Tow EX's Avatar
Default Re: HELP! tail light problem!!! (AH Tow Ex)
stay on top please.
Old Sep 12, 2002 | 10:35 AM
AH Tow EX's Avatar
Old Sep 12, 2002 | 10:42 AM
jArceo's Avatar
hmm i kinda had the same problem.. i had lost the screw when replacing bulbs in my turn signals.. so i drove slowly to autozone to see if they had it.. but they didnt
well needless to say i forgot about it and when leaving the parking lot a lil fast.. i crushed the whole signal light lens and it went flying behind me
fortunately all it did was mess up the turn signal on the right... so when i used the left blinker its normal.. but when i used the right blinker it would go 4x as fast or so
i just compromised by getting a 4x blinker
i never could find out wat was wrong cuz i still had all my wires and bulbs there
Old Sep 12, 2002 | 10:45 AM
obd2gsr's Avatar
you probably have shorted out the fuse. your rear taillights and interior lights are the same fuse, so check out your fuse box, and if you haven't yet replaced those broken connections, the least you could do is stick some electrical tape on it, so that another short doesn't happen again. otherwise, you'll just continue to replace fuses... hope that helps.
Old Sep 12, 2002 | 10:56 AM
AH Tow EX's Avatar
Default Re: HELP! tail light problem!!! (obd2gsr)
hey thanks a lot guys, i checked the fuses and they appear to be fine, but i'll replace them and see what happens.
Old Sep 12, 2002 | 12:35 PM
obd2gsr's Avatar
you literally pulled them all out to see if any were busted?
Old Sep 12, 2002 | 01:30 PM
uNF$@#!'s Avatar
its your fuse. you blew a big one. check in both fuse boxes.
92_JDM
Lighting
Mar 17, 2010 08:23 PM
RedJdmEk4
12
Oct 3, 2009 09:33 PM
em2power
Honda Civic (2001 - 2005)
Jan 5, 2008 07:17 PM
[626]phixionEF91
20
Feb 8, 2003 03:03 PM
