help with struts
Old May 24, 2008 | 07:23 PM
dion91Ls's Avatar
Default help with struts
okay yesterday i did an oil change on my car, and so i lifted my car up on the drivers side. I was done with the oil change and put everything back together and then i put the car down and when i try to close the hood it wouldnt shut and i look and see my strut on my passanger side sticking up. I took the strut out and looked at it and tightened it up and put it back and the same thing happend it would not go down. any help
by the way i have a 91 acura integra
and tokico blue struts
Old May 24, 2008 | 07:26 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help with struts (dion91Ls)
The shock is installed from the bottom. Inspect the shock tower for damage. Perhaps you should post a picture.
Old May 24, 2008 | 07:56 PM
dion91Ls's Avatar
Default Re: help with struts (Dogginator)
only pic i can get
Old May 24, 2008 | 08:37 PM
Sic_DA_Nine's Avatar
you forgot a washer
Old May 24, 2008 | 10:23 PM
numberone's Avatar
Default Re: (Sic_DA_Nine)
That fat washer on top is suppose to go on before the strut tower dust cover.
Old May 24, 2008 | 10:45 PM
dion91Ls's Avatar
so is it supposed to b inside that hole?
Old May 25, 2008 | 04:22 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (dion91Ls)
This shows the assembly order:
http://www.acuraoemparts.com/d...ch=no
Is part of the shock rod rough like a piece has broken? To me it looks like a welded collar has broken free and the shock needs to be replaced. Part 12 from the diagram would rest on that missing collar.
Old May 25, 2008 | 06:17 AM
lmike6453's Avatar
haha wow...sry it's funny...
but yea if the "shaft of the strut, shiny metal, is dinged up; when it penetrates the strut it will rip it
Old May 25, 2008 | 07:09 AM
be18see1's Avatar
Default Re: (lmike6453)
its a shock. just so you all know. it looks like its broken, especially if you didnt touch it while you under the car.
Old May 25, 2008 | 12:55 PM
dion91Ls's Avatar
thanks for the help everyone, i fixed the problem
Old May 25, 2008 | 05:27 PM
be18see1's Avatar
what was it?
Old May 25, 2008 | 10:09 PM
dion91Ls's Avatar
Default Re: (Dogginator)
[QUOTE=Dogginator]This shows the assembly order:
i just needed a new strut mount
part #12 was bad
rollinhonda3
Sep 11, 2010 11:36 AM
DanG0r3
Apr 13, 2010 09:51 PM
dion91Ls
Suspension & Brakes
May 25, 2008 12:56 PM
