Help/Skunkwork coilover
Old Oct 9, 2006 | 05:58 AM
909ej195's Avatar
Default Help/Skunkwork coilover
wus up yall i just bought sum coilover from a member off honda tech but he wusnt sure what spring goes to the front or back so i need yall help. There four springs two with the number 0700.2.50.006 and the other is 0700.2.50.008 so what goes to the front and what goes to the back thanks for yall help
Old Oct 9, 2006 | 03:47 PM
rgaray's Avatar
You can call skunkworks and ask them to be on the safe side. My buddy went through the same thing.
Old Oct 9, 2006 | 03:58 PM
jspec-integ Ls's Avatar
Default Re: Help/Skunkwork coilover (909ej195)
the 0700.2.50.008 is for the front and the 0700.2.50.006 are for the rear, the only way you can tell are the last numbers on the stamp the 8 which means 8k spring rate and the 6 for the rear for 6k spring rate. I have a set of skunkworks on my db8.
Old Oct 9, 2006 | 04:08 PM
BlueIntegraBoy's Avatar
Stiffer spring in the front, softer in the rear.
Old Oct 9, 2006 | 07:55 PM
909ej195's Avatar
thanks for the help yall
johnls
Mar 9, 2007 05:42 AM
92hatchattack
Suspension & Brakes
Jun 11, 2006 06:06 PM
Ruthless DC2
Suspension & Brakes
42
Dec 29, 2005 02:27 PM
jonGSR
Mar 7, 2004 10:11 PM
sivik2nr
Jul 2, 2003 05:03 AM
