help! running over-lean
Old Mar 4, 2012 | 09:40 PM
DawgC2's Avatar
Default help! running over-lean
i had a cel and had it dignosed by a snapon scanner. came up with car running overlean the mechanic said it could be something wrong with the fuel system such as the fuel pump or FPR. my car starts up fine but the idle was rough and stays low at 500 rpm. acceleration sucks!!!! it also misfires. i have new cap and rotor, plugs, and fuel filter. plus a valve adjustment. any insight??
Old Mar 5, 2012 | 05:37 AM
cdaiscool's Avatar
Default Re: help! running over-lean
How's your fuel pressure, have you checked it? I wouldn't drive it much while it's so lean, as it could blow a few expensive parts in the motor.
Old Mar 5, 2012 | 05:43 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^, stop running the engine untill problem solved, running rich will get you crappy milage, running lean can get ugly.
As mentioned, check fuel pressure, also check 02 sensor. 94
Old Mar 5, 2012 | 07:16 PM
el crapitan's Avatar
vacuum leak(s) can result in a lean code as well
try removing the intake boot and covering the throttle opening. if it runs, there is a leak
Old Mar 10, 2012 | 12:11 PM
DawgC2's Avatar
O ****! i been driving it for couple weeks !! what could be messed up from driving a overlean motor??
blackhatchsd
Feb 25, 2007 08:26 PM
dj_seloe
Oct 15, 2003 07:32 PM
jeremy.
Sep 27, 2003 02:12 PM
2000CX
Aug 14, 2003 05:15 PM
speedaccordinly24
Apr 25, 2003 04:15 AM
