help with removing a hose!!!!!!!!!!!!!
Old Jan 19, 2003 | 07:27 PM
f1YONSdc2's Avatar
New User
Default help with removing a hose!!!!!!!!!!!!!
anyone have any tips on how to remove the hose under the throttlebody with coolant inside.. it is a thin hose.. i cant seem to get to the clamp.. there is no room.. any tips or help would be nice.. thank...yons1
Old Jan 19, 2003 | 08:47 PM
SargentNg's Avatar
Default Re: help with removing a hose!!!!!!!!!!!!! (f1YONSdc2)
Try twisting it while pulling.
Old Jan 19, 2003 | 09:14 PM
f1YONSdc2's Avatar
New User
Default Re: help with removing a hose!!!!!!!!!!!!! (SargentNg)
i dont have a bent needle nose, what other options do i have.. i am already dirrrrrrrrty....
yons1
its the clamp i am having a hard time removing...
[Modified by f1YONSdc2, 6:18 AM 1/20/2003]
Old Jan 19, 2003 | 09:58 PM
GirlyGS-R's Avatar
Like everoyne else said, the bent needle nose seems like your best friend!
Old Jan 20, 2003 | 06:31 AM
TimoneX's Avatar
New User
Default Re: help with removing a hose!!!!!!!!!!!!! (GirlyGS-R)
I cut mine. Right at the end of the fitting from the sensor on the bottom of the IM. There's plenty of slack and if not it's a cheap hose anyway. Don't make this tougher than it needs to be. Plug it with a bolt when you get it off.
Old Jan 20, 2003 | 07:05 PM
stumpyf4's Avatar
Default Re: help with removing a hose!!!!!!!!!!!!! (TimoneX)
^^^^ what he said. Tugging and twisting can put too much strain on the fitting and it can break off.
PSI Racing
10
Jan 27, 2020 04:28 PM
stevenDAtegra
May 7, 2009 08:28 PM
Hondatuner88
Welding / Fabrication
Feb 13, 2008 06:56 PM
txracer
Aug 24, 2005 08:58 AM
boot machine 5000
May 21, 2003 02:16 PM
