help With Random Missfire
Old Jun 25, 2009 | 07:05 PM
lazii_boi08's Avatar
Icon6 help With Random Missfire
Im on my way to PA when all of a sudden my check engine light starts blinking and I hear a hissing sound I pull over and poped my hood an came to see my motor is missfiring I luckily still made it to my mechanics and they said my my motor's head is bad which I dont get because i dont really push my car or race and I did my tune up and oil change back in febuary my only mistake is I never did a compression test.
By the way I own a 98 Integra GSR
when I check out the codes I was throwing codes on cylinder1,2,3,4 and then another code that read Random Multiple Cylinder missfire cound the mechanics be wrong cause I was there with them they checked it by pulling out the spark plug cable and the the one to driver side did not spark nor the one to the left side of it???
Old Jun 25, 2009 | 08:28 PM
ek-g6's Avatar
Default Re: help With Random Missfire
how's the cap and rotor? They might have gone bad.
Old Jun 25, 2009 | 08:35 PM
I changed the cap back in febuary to but I know this may sound stupid but could a bad rotor button really make my car missfire on only 2 cylinder unless of course the cap is bad to???
Old Jun 25, 2009 | 08:40 PM
ek-g6's Avatar
yeah, but check both to make sure, how are your ignition coil, or spark plug wires?
Old Jun 25, 2009 | 08:49 PM
ok ima check that 2 but damn from your opinion do you the head could go bad like that cause my friend said he doubt it he said it could be my dizzy or probably fuel injector not working
Old Jun 25, 2009 | 08:58 PM
Marcos Barrios's Avatar
yea dude heads dont just go out like that
it sounds to me like it could be your dizzy
Old Jun 25, 2009 | 09:08 PM
ek-g6's Avatar
I really doubt your head went bad, and I don't think it would cause it not to spark two cylinders unless those two cylinders have bent valves. You could change out the dizzy with your friend or something and either confirm or not that it is the dizzy.
Old Jun 25, 2009 | 10:44 PM
yea I doubt that to because my valve's are really quiet you dont really hear them click like that
but ima check on all that tomorow Thank you for your help ek-g6 and Marco barrios I'll let yall know how it turns out.
Old Sep 21, 2009 | 08:11 PM
w211 ryda's Avatar
Got the same codes, was wondering if you got your CEL cleared...if so what was the fix?
fcm
May 18, 2016 04:22 AM
ek95
Dec 13, 2012 06:30 AM
CUTTERSPOOL
Jun 16, 2009 05:11 PM
EL TYPE R
Jan 30, 2009 04:19 PM
Ideal
Oct 18, 2005 02:20 PM
