help quick!
Old Jun 2, 2008 | 01:51 PM
hastingsr's Avatar
Default help quick!
I need to remove my cv axle by 2 hours so I can get my alternator off. When I go to remove the axle nut on the hub I can get the hub to not move. I have a big *** breaker bar and when I try to break the nut free it acts like it wants to stay but the it slowly moves and I get no where. HELP PLEASE!!
Old Jun 2, 2008 | 02:52 PM
hastingsr's Avatar
okay i got the cv nut off, now the rotor is frozen, any sugestions?
Old Jun 2, 2008 | 03:15 PM
Jimmy's Avatar
Global Moderator
Default Re: (hastingsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hastingsr &raquo;</TD></TR><TR><TD CLASS="quote">okay i got the cv nut off, now the rotor is frozen, any sugestions?</TD></TR></TABLE>
What do you mean the rotor is frozen?
There are two hold down screws holding the rotor on.. Did you remove them?
Then remove the caliper bracket and you should be able to slide the rotor off..
Old Jun 2, 2008 | 03:18 PM
steveo135's Avatar
Default Re: (Jimmy)
are you talking about the bolt on the end of the axel?
If you put the tire on the car and lower it on the ground that will stop it from spinning while you break it loose
not sure if thats what your talking about though
Old Jun 2, 2008 | 05:49 PM
Dogginator's Avatar
Daisy... Daisy...
The rotor is stuck on the hub? Try the jacking screws on the rotor or a nice dead blow hammer.
Old Jun 2, 2008 | 08:35 PM
hastingsr's Avatar
thanks for the tips guys, i got it all figured out just in time, thanks to some friends of mine that came over to lend a hand also
Charlie Moua
Jul 1, 2013 10:04 AM
itr1244
Apr 14, 2008 12:25 PM
gursh d
Apr 5, 2007 10:51 AM
EG2Driver
Jun 6, 2006 08:50 PM
gamblezhang
Apr 11, 2006 07:54 AM
