Help - problem after cap/rotor install
Old Feb 2, 2004 | 07:13 PM
imp0rtedrice's Avatar
Default Help - problem after cap/rotor install
My problem: long starts in to crank engine
This started occuring the second day after i installed my new cap/rotor/ngk copper plugs/ and wires. Im pretty sure i did the install right with 20lbs of torque on each plug.
I put the wires back on the distributor in correct order starting from bottom left to bottom right to top left to top right order.
After i finished my install two days ago, the engine turned on instantly and everything was smooth and running fine.
So now my engine takes a while to crank. I can't figure out the problem; i checked the plugs with correct torque specs. ANY help would be much appreciated thanks all.
Old Feb 2, 2004 | 07:40 PM
help
Old Feb 2, 2004 | 07:51 PM
4U2NV's Avatar
Default Re: Help - problem after cap/rotor install (imp0rtedrice)
The same **** happened to me, but I just played it off as cold weather... Now that I think about it it was right after cap/rotor/plugs/wires... Do you let the motor prime fully before you start it or just crank right away...?
Old Feb 2, 2004 | 07:55 PM
Huh_oh Shit!'s Avatar
Right after I installed brand new cap, rotor, plugs, and wires, the crank time was quicker to start the motor for me. But when the temperature gets below freezing, it takes a little longer. It COULD be the colder weather.
Old Feb 3, 2004 | 12:01 AM
i garage it...But such a disspointment from the first crank that started instantaneously to the crank that sounds like ****.
Old Feb 3, 2004 | 12:06 AM
gsrguy's Avatar
* B A N N E D *
Default Re: (imp0rtedrice)
its cold weather bro, my teg takes 3 cranks on very cold mornings
Old Feb 3, 2004 | 02:23 PM
really? The long cranks only started happening after the new parts. It should only get better with copper plugs due to a better conductive metal? Plus the new cap/rotor
Old Feb 3, 2004 | 02:59 PM
tumbleweed's Avatar
are they colder plugs than the stock plugs?
Old Feb 3, 2004 | 03:33 PM
Riceburner247's Avatar
Default Re: (tumbleweed)
Are your spark plugs gapped to the right specs?
Old Feb 3, 2004 | 08:00 PM
well the company told me it was already pre-gapped. But im going to check it out over the weekend to make sure and see if there is a change.
Old Feb 3, 2004 | 08:48 PM
4U2NV's Avatar
I've found that if I let my car prime fully and allow the CEL to go off before I start to crank my car, it will take several cranks to "catch" and actually start... However, if I try to crank immediately after turning the key "on" it will start with no hesistation, within a crank or two...
91AcTegra
Nov 15, 2016 01:00 PM
Tong.Y
Apr 9, 2010 12:04 PM
NOOdS
Feb 13, 2009 02:31 PM
wiseguyoncouch
Jan 30, 2008 09:47 AM
2ndName
Jan 30, 2006 11:32 PM
