help please
Old May 26, 2007 | 10:59 AM
mrJDM_DB8's Avatar
Default help please
i have a tech question, i put in a gsr head on my ls block, and i put on a skunk2 manifold, now theres a vacuum line in the back of the maifold that goes no where but when i plug it then my motor dies, and it runs when the line is not pluged. i didnt do the install cause i had the motor all re-built,
its the inlet on the back near the fire wall beside the inlet with a 90 bend that goes to the brake booster. if anyone has any idea it would help me. please and thanks
(so the hose is pointing towards the firewall)
Old May 26, 2007 | 11:01 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help please (mrJDM_DB8)
It sounds like the hole is a vacuum leak. Since the car stalls with it properly plugged, you more than likely need to set your base idle. There is an adjustment screw on the throttle body.
Old May 26, 2007 | 11:03 AM
mrJDM_DB8's Avatar
Default Re: help please (Dogginator)
so would i need to set the idle higher? or what does that do? thanks Dogginator i will try that after work
Old May 26, 2007 | 11:05 AM
Dogginator's Avatar
Daisy... Daisy...
You will most likely need to open the idle screw more.
Have you tried to start the car with the vacuum connection blocked? Sometimes if you suddenly block a vacuum leak the engine will stall.
Old May 26, 2007 | 11:21 AM
mrJDM_DB8's Avatar
humm, that is a good point, i will try that too, thanks dude, i'll post tonight if it worked or not.
dustinbs144
Jun 18, 2011 09:37 AM
screen_name
34
Sep 19, 2005 01:10 AM
JayDM_lsvtec
Nov 3, 2004 07:45 PM
Tx92AccordExD
Jan 14, 2003 09:23 PM
