Help with Pivot Tachometer Install
https://honda-tech.com/forums/images...s/emsmilep.gif So my friend gave me his Pivot Tachometer but he doesent remember how to wire it back up to a Integra....also It didnt come with any instructions.. all I know is that it has 4 wires...White / Black / Red / ORange .... I believe Black is Ground and Red is to a 12v source... but where do i hook up the other two wires???
Pix will be helpful.....Thanks in Advance https://img.photobucket.com/albums/v...Ride/Pivot.jpg https://img.photobucket.com/albums/v...ide/Pivot2.jpg |
Re: Help with Pivot Tachometer Install (PhantomX)
All wires can be hooked up to wires behind the gauge cluster.
<u>Tachometer Wire ---> Cluster Harness Wire</u> Black ---> Black (or dash bolt) [ground] White ---> Red/Black [illumination] Red ---> Black/Yellow [12v] Orange ---> Blue [signal] |
Re: Help with Pivot Tachometer Install (BlueIntegraBoy)
ok kool... thanks
for the BLUE "signal" wire.... do i tap it to the harness that only has 3 wires? (farthest yellow harness to the right if you were facing the gauge cluster)
