help with a noise..
Old Sep 8, 2005 | 08:02 PM
xscape's Avatar
Default help with a noise..
hey guys,
i own a '94 vti-r (GSR) integra with 150,000 kms on the dial. car has always been well looked after, regularly serviced and given a daily dose of vtec.
i noticed that the engine makes a wierd sound, only between 1800 - 2500 rpm or so.. its a sort of metallic ting ting ting ting sound, coming from inside the head.
wondering if anybody knew what it could be?..
thanks.
Old Sep 8, 2005 | 09:57 PM
ImXposed's Avatar
Needs $$ for a Hooker
my LS did that, if im thinking the same thing. My mechanic friend said I needed a valve adjustment. Check that, and ur oil definitely, maybe an oil change... mine stopped about 200 miles after i did an oil change and filter change. hope this helps.
Old Sep 8, 2005 | 10:01 PM
LSRracing95's Avatar
Default Re: help with a noise.. (xscape)
exhaust leak or rattle maybe.. i thought the same thing when i heard my noise.. thought it was something in the head... thoroughly check each connection on your exhaust, gaskets and make sure no bolts are loose or broken
integra_101
Apr 13, 2014 02:39 PM
VihnSta2
Mar 9, 2010 07:04 AM
JDM-EJ1
Jun 12, 2004 03:10 PM
2005 TSX
Dec 10, 2003 03:23 PM
nugget8000
Nov 25, 2001 09:01 PM
