Help, no power to fuel pump!
Old Apr 12, 2002 | 07:50 PM
Ri5e's Avatar
Default Help, no power to fuel pump!
Car doesn't start. Fuel pump works but there is no power going to it. What could be the problem? A cut wire? IF its a cut wire, what possible places can the cut be at?
Thanks!
Old Apr 13, 2002 | 11:37 PM
kkim's Avatar
Default Re: Help, no power to fuel pump! (BG Boost)
did you check the fuse?
Old May 13, 2011 | 08:35 AM
pgravco's Avatar
I have the very same problem, the fuse is good, i changed the main relay it is also good,
but there is no power to the pump
i do now what it is may be a bad wire i also checked them everthing looked ok.
so i think it is the ECU but not sure
thanks
Old May 13, 2011 | 09:25 AM
FF for Life's Avatar
Check for power at the fuse (touch the little exposed metal pins on top of the fuse with a test light....both of the pins) then check for power on the wire that carries power to the fuel pump at all connectors all the way to the pump. It could also be that the pump is getting a bad electrical ground connection.
Old May 13, 2011 | 09:44 AM
hybrid90's Avatar
It's most likely your Main Fuel Relay. On hot days, the solder inside the unit tends to crack and expands thus not giving piwer to the pump.
Unplug that sucker and open it up and drip fresh solder on all the connects and you should be good to go.
Old May 13, 2011 | 10:48 AM
pgravco's Avatar
the main relay is brand new and it clicks
so i think it is either wiring or ecu
does anyone have the wiring diagram
thanks
Old May 13, 2011 | 10:52 AM
pgravco's Avatar
I checked the fuel pump fuse on both ends there is voltage.
can you tell me from the battery what is first then what comes next? is it like battery, fuse, relay and fuel pump? does ECU or ignition switch get involved in anywhere?
Thanks
Old May 13, 2011 | 11:14 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help.
The PGM-FI Main Relay has 3 fuses, a 12V+ constant, [hot at all times], a 12V+ switched, [hot in run and start] a 2nd 12V+ switched, [hot during cranking to start only].
There are number of things that would prevent the fuel pump from running.
I need the MM&Y to help.94
Old May 13, 2011 | 11:46 AM
pgravco's Avatar
It is 1998 Honda Prelude
the relay has 7 prongs
Old May 13, 2011 | 02:03 PM
pgravco's Avatar
any ideas if it could be the ECU
Old May 13, 2011 | 04:49 PM
fcm's Avatar
fcm
Old Fart
It could be the ECU/ECM as it provides the ground for the fuel pump relays coil, the other side of coil gets it's power from the output of the fuel injector relay.
Sorry I do not have a wiring diagram for a 98 Prelude.
If you have a 12V test light you can do some tests that do not require the wiring diagram.
Unplug the PGM-FI Main Relay...
With the ign. switch off, test the leads in the plug, there should be a 12V+, [hot at all times], if so, what color is it?
Turn ign. switch on to run position, there will now be another lead with 12V+ on it, [hot in run and start] turn ign. key to start to make sure the lead still has 12V+ on it, if so, what color is it?
Now turn ign. switch to start, there should now be a 3rd lead with 12V+ on it, [hot during cranking to start only] if so, what color is it?
There will also be a black lead in the plug, it is ground for the injector relays coil, the lead that is hot in run and start is on the other side of injector relays coil, that lead is also power for the fuel pump, [through fuel pump relay]
That is 4 of the leads the other 3 leads are...
1- The fuel pump power lead, [most likely a yellow/green or yellow/black].
2- the injector power lead, [it may also be yellow/green or yellow/black].
3- the ECU/ECM fuel pump relay control lead, [possibly a green/black or green/blue]
Give me the colors of the 3 leads with 12V+ on them and the colors of the other 3 leads, and I will give you some other tests to try. 94
Old May 13, 2011 | 06:47 PM
pgravco's Avatar
Thank you for your help.
I will get those to you most probably on Monday.
Thanks
Old May 15, 2011 | 08:58 PM
pgravco's Avatar
Hello back.
Here are the answers to your questions:
With the ign. switch off, test the leads in the plug, there should be a 12V+, [hot at all times], if so, what color is it?----NO VOLTAGE IN ANY LEAD
Turn ign. switch on to run position, there will now be another lead with 12V+ on it, [hot in run and start] turn ign. key to start to make sure the lead still has 12V+ on it, if so, what color is it?----ONLY NUMBER 6 LEAD HAS VOLTAGE. THE COLOR OF WIRE IS BLUE WITH RED STRIPE
Now turn ign. switch to start, there should now be a 3rd lead with 12V+ on it, [hot during cranking to start only] if so, what color is it?---NUMBER 6 AND NUMBER 5 LEADS HAVE VOLTAGE.. THE COLOR OF WIRE TO LEAD 6 IS BLUE WITH RED STRIPE....THE COLOR OF WIRE TO LEAD 5 IS RED WITH ORANGE STRIPE.
Thanks for your help in advance. Please let me know what you think
Sincerely
Old May 16, 2011 | 11:27 AM
fcm's Avatar
fcm
Old Fart
Your problem is no constant power, [is there a yellow/white lead] check the fuses in the engine bay fuse box, most likely a 15A fuse.
With no constant power there is no fuel injector relay output, so no power to injectors, no signal to ECU/ECM, [IPG1 & 2] no power to fuel pump relays coil, [unless cranking to start] and no power to a few engine solenoid/valves.
With no signal the ECU/ECM there will be no fuel pump relay control output or injector pulse from ECU/ECM. 94
Old May 17, 2011 | 02:21 PM
pgravco's Avatar
Hello I checked all the fuses there is non that don't work.
there is also no yellow and white lead...
one thing though, ABS fuse is not broken but there is no voltage in either end of the fuse.
Is it because the car is not starting and running
or is it something else?
The other thing is that I scanned the car unfortunately it did not give me any code instead it said "error" even though my check engine was on due to catalytic converter.
Let me know what you think please thanks
Old May 18, 2011 | 05:27 AM
fcm's Avatar
fcm
Old Fart
Then there is a connection problem between the fuse and the PGM-FI Main Relay. 94
What are the other wire colors in the PGM-FI Main Relay plug? 94
Old May 22, 2011 | 07:53 PM
pgravco's Avatar
Hi just an update and i need more advice
I just replaced the ECU now I got the power to fuel pump.
On the relay I have now 1,5,6, and 8 powered up.
I also have fuel and sparks.
but it still does not start please let me know what i should check now
thanks.
i scanned it it gave me 0.
check engine light when key is on comes on and turns off as it should..
Old Jul 13, 2023 | 02:06 PM
Kayche's Avatar
Thanks
Where is the ecu located?
Old Jun 4, 2024 | 08:52 AM
Ford05's Avatar
Wondering if there’s any follow up to this post. I’m having the exact same problems and don’t know where to go from here.
redline1320
Apr 27, 2010 06:55 PM
2fast4urass
Feb 18, 2010 08:21 PM
EG MikE
Jun 1, 2009 01:36 PM
SiRay13
Oct 9, 2006 09:58 AM
HatchBox
29
Oct 5, 2004 04:12 PM
