HELP! NO FUEL!!!
Old Jun 24, 2025 | 01:49 PM
OneSlow90's Avatar
Default HELP! NO FUEL!!!
I just purchased my first DA integra, the LS special for 900 bucks. I was able to test drive it but then the "fuel pump went out" I put a new pump in, checked main relay with a know good one, made sure all grounds were solid but there is still no pressure getting to the filter. After reading around I'm entirely lost. Help!!!
Old Jun 24, 2025 | 07:23 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: HELP! NO FUEL!!!
check your fuses
Old Jun 24, 2025 | 07:50 PM
OneSlow90's Avatar
All fuses are intact.... it ws one of the first things I checked. Any specific fuses that would cause this problem??
Old Jun 26, 2025 | 03:22 AM
wunfstgsr's Avatar
Loved
Community Favorite
Could also be a problem with the ECU, you might have to start testing the power signals going to the fuel pump and from the fuel pump to the ECU to see where the signal is dead.
Old Jun 26, 2025 | 10:33 AM
POSonda's Avatar
5 Year Member
Are you hearing the pump priming? I experienced a similar issue after replacing my gas tank and fuel pump. I wasn't getting fuel pressure at the filter. Upon closer inspection, I found that the filter had disconnected from the pump due to it not being seated properly. After securing it, the engine started right up.
jdmoutkast
Jul 7, 2007 12:21 AM
nicko360
15
Jan 17, 2007 06:22 PM
jdm2teg
Oct 13, 2006 05:13 PM
SwIntegraB16
Apr 10, 2005 09:41 PM
