help needed about hids
Old Jun 30, 2008 | 07:53 AM
97_dc2's Avatar
Default help needed about hids
was wondering which size bulb needed. is it the h4 or the 9006?
Old Jun 30, 2008 | 08:47 AM
95TegSE's Avatar
Default Re: help needed about hids (97_dc2)
What kind of HID are you talking about? Because the 9006 is just a regular halogen bulb. If you're talking about real HIDs (retrofit) then I believe you need a d2s. They usually cost you an arm and a leg (~$150/pair).
Old Jun 30, 2008 | 08:52 AM
hypd23's Avatar
scince ur name is 97_dc2 ill assume its for a 97 integra. anyway u need the 9006 for lows or 9005 for highs.
Old Jun 30, 2008 | 10:00 AM
97_dc2's Avatar
Default Re: help needed about hids (hypd23)
thanks. it was for a hid kit since i retrofitted my headlights and yes it was for a 97 integra.
Old Jun 30, 2008 | 10:03 AM
dc2_916's Avatar
http://www.vvme.com for cheap hids.72.99.thank me later.haha
Old Jun 30, 2008 | 11:29 AM
infamouskillas's Avatar
Default Re: help needed about hids (dc2_916)
you need 9006...those numbers represent the type of car it will fit in, not if its halogen or not
-ian
Old Jun 30, 2008 | 12:00 PM
jomama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">thanks. it was for a hid kit since i retrofitted my headlights and yes it was for a 97 integra.</TD></TR></TABLE>
wow, there's a lot of misinformation in here. if you retrofitted with OEM projectors, ballasts, etc... you should be using either d2s or d2r bulbs... depending on the car the parts came from. more likely than not, you should be using d2s bulbs... which are not:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE &raquo;</TD></TR><TR><TD CLASS="quote">What kind of HID are you talking about? Because the 9006 is just a regular halogen bulb. If you're talking about real HIDs (retrofit) then I believe you need a d2s. They usually cost you an arm and a leg (~$150/pair).</TD></TR></TABLE>
. you can get them cheaper on ebay or from members here on HT. I'd go with near OEM 4100-4300k bulbs... phillips over osram bulbs... IMO.
however, if you went the cheap-***-ghetto route of using the plug in play sh*t and stuck with your OEM integra projectors, you should be using 9006 bulbs for the low beam... if you went this route, you do not have HID.
GL
nickyturbo
Lighting
30
Jun 23, 2012 10:21 PM
MurtazaDSM
Jan 22, 2011 10:29 AM
GuCBlackEk
Sep 2, 2009 10:38 PM
JustinL
Sep 14, 2004 03:28 AM
superthug
Feb 24, 2003 08:43 PM
