help with ignition timing!!!
Old Nov 1, 2013 | 07:13 PM
jdmsleeper12's Avatar
Default help with ignition timing!!!
jdm 1997 spec R motor
so if i look straight down from the front of my car with the timing gun,
ON THE PULLY!
1 sinlge mark....< mechanical light rite? dont worry about it?
1 three mark...<<<<<THESE are the one im focusing on?
2 middle
3 last.
which way is advance? 1 < is where the arrow on my cover is pointing at correct?
rite now i have the arrow pointing at #1 2.0 on the gun? is that 18 degree?
Old Nov 1, 2013 | 07:50 PM
HondaMotive's Avatar
Default Re: help with ignition timing!!!
ON THE PULLY!
2 middle
3 last.
Im half lost in your question.
Warm the car up fully.
Unplug the IACV plug and get the car to idle at 750 +/-50RPM and jump your service connector under the passenger side kick panel.
If you have an adjustable gun, set it to 0
Place the lead on the #1 spark plug wire and make sure there's no interference.
Point the light down. You are looking to align the middle of the 3 marks with the marks on the timing cover witch is 16. The single mark is the TDC mark for checking mechanical timing.
Old Nov 1, 2013 | 08:17 PM
B_Swapped93's Avatar
this^
did you jump the connector OP ? I've never heard of unplugging the iacv tho ? not saying you're wrong just not familiar with that way of doing it.
Old Nov 1, 2013 | 08:21 PM
Originally Posted by B_Swapped93
this^
Sorry this is meant to bring the idle down to 750. Alot of cars I see these days with intake mods ect seem to be idling a bit high, so usually unplugging the IACV brings it right around 750.
Old Nov 1, 2013 | 09:07 PM
rite now, the arrow on my cover is pointing at the 1st one of the three...my question is.. out of the 3... which one is advance?
Old Nov 1, 2013 | 09:09 PM
does it go?? im looking straight down from my frontend of the radiator.
the 3 thats together, which line is the advance?
14......18
16......16
18......14
Old Nov 2, 2013 | 05:27 AM
kaycee_00's Avatar
NENET
Aug 31, 2010 11:01 PM
Opponentkhaos
Aug 2, 2008 11:27 AM
civic j
Aug 17, 2007 08:10 AM
dsCRXsi
May 2, 2004 04:32 AM
