Help! I can barely Shift
Old Oct 20, 2001 | 07:03 PM
Yyz's Avatar
Yyz
Default Help! I can barely Shift
For some reason it is very hard to shift into any gears especially 3rd. My clutch doesn’t feel loose or anything, but for some reason I cant always get into gear with out any effort. What could possibly be wrong?
Old Oct 20, 2001 | 08:00 PM
2005 TSX's Avatar
Have you done any upgrades to the transmission lately? Racing, tracking the car, mis-shifted, over-revved? Any more details that you can tell us?
Old Oct 20, 2001 | 09:29 PM
Yyz's Avatar
Yyz
Default Re: Help! I can barely Shift (2001 Integra GSR)
I haven’t done anything to the transmission. It is all stock. I never race the car and I drive pretty easy. And I can’t think of any major mishifts lately. Just the normal miss every once in a while, but not while I am accelerating extremely fast. I was driving the car a little hard today on the highway but I never dropped below 4th gear.
Could it be a clutch problem? I am not sure when the clutch was replaced, but I know that I haven’t replaced it. How do you know if your clutch is going bad?
Old Oct 20, 2001 | 09:42 PM
2005 TSX's Avatar
Default Hmmm...
Just a couple more questions. Did you buy the car new or used? If it is a new car, take it to the dealer, as long as it is under warranty. How old is the car?
Old Oct 20, 2001 | 10:06 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Help! I can barely Shift (Yyz)
Bad synchros?
Old Oct 20, 2001 | 10:14 PM
Yyz's Avatar
Yyz
Default Re: Hmmm... (2001 Integra GSR)
I bought the car used( it is a 1995), but i bought it used with 35,000 miles on. So I put the majority of the miles on it. What sucks is that it isnt under warranty, so when things go worng I have to dig pretty far into my pocket to pay for them. i think I am going to take it into the dealer next week and have them take a look at it.
Old Oct 20, 2001 | 10:22 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Hmmm... (Yyz)
might be as simple as low transmission fluid... i run amsoil series 2000 ow-30 synthetic motor oil in my tranny.... it helps it shift smoother and it will last longer. when i had my transmission built, this is what my mechanic used and he said not to use anything else in it if i wanted it to last years and years to come. Just my $0.02 though, I'd definatly check the fluid though, and if you can get the Amsoil, it would be a lot cheaper than trying to rebuild or what have you
Old Oct 20, 2001 | 11:01 PM
Yyz's Avatar
Yyz
Default Re: Hmmm... (Pb_Foot)
cool, Ill check the fluid level tomorrow. Thanks
Old Oct 22, 2001 | 11:47 AM
Yyz's Avatar
Yyz
Ok I check the fluid level and it is ok. But today the probelm got worse.
I put the clutch all the way in and when I tried shifting into fourth while moving it grinded the gear. But the clutch pedal doesnt feel like it loose. It feels like it always has.
Old Oct 23, 2001 | 06:16 AM
Inigo Montoya's Avatar
Default Re: (Yyz)
It sounds like the same problem i had with my old car (saturn) it turns out that my slave cylinder for the clutch died. I have the shop replace it and things improved dramatically, although they said that i would need to replace the entire clutch in a year. I ended up selling the car before then, but you may want to have the shop look at the master and slave cylinder on the clutch. If not, well if you have to replace it at lease go with a slightly nicer clutch.... It will probably cost you less than 100 bucks more than one from the dealer, or maybe even less.
Old Oct 23, 2001 | 07:09 AM
Phat Corolla's Avatar
New User
Default Re: (inigo9910)
We've had a lot of topics devoted to these clutch problems lately. Look somewhere back a few pages here in the integra forum. I think there's also some topics in members corner about it. good luck.
Condor018
Oct 19, 2006 10:07 PM
lokodog
Dec 25, 2005 09:39 PM
JDMlyfestyle
21
Sep 24, 2004 02:08 PM
Chief Brody
Aug 4, 2004 09:28 PM
