HELP HELP HELP HELP HELP!!!!
Old Apr 27, 2002 | 02:16 PM
Phat Corolla's Avatar
New User
Default HELP HELP HELP HELP HELP!!!!
Hey guys...I managed to break something just now.
I have this noise that I'm trying to troubleshoot, so I took off my dist. to take a look at it and put some grease on the shaft. (The noise is a bearing noise, I think) Well, I put it back on and then proceeded to wash my under-hood area. I made sure to cover the fuse box, dist., air intake, and battery. After I was done washing it, I tried to start my car up and it won't start. It will attempt to turn over, but there seems to be no spark. I pulled one of the spark plugs, and sure enough...no spark. What did I do to it? Any clues?
Any help would be appreciated.
Old Apr 27, 2002 | 02:30 PM
New User
Default Re: HELP HELP HELP HELP HELP!!!! (Phat GS-R)
Please!!!!
Old Apr 27, 2002 | 02:54 PM
Tweakmeister's Avatar
Check the distributor again and make sure it's all lined up and you didn't advance/retard the timing.
Old Apr 27, 2002 | 03:05 PM
New User
Default Re: HELP HELP HELP HELP HELP!!!! (Tweakmeister)
I just did that...I took everything apart and put it back together. Still no spark. How could I have messed up anything??? I still don't get that. This is starting to **** me off.
Old Apr 27, 2002 | 04:42 PM
New User
Anyone else???! This sucks
Old Apr 27, 2002 | 04:50 PM
FrostyGSR's Avatar
New User
Well I can almost be sure that whatever you did to the dist. is the reason the car won't start. I power wash my engine 3-4 times a year and I just cover the dist. and air filter.........she starts right up every time after......explain again what you did with the dist? Did you line everything up right when reinstalling it?
Old Apr 28, 2002 | 07:14 AM
Chubz's Avatar
Default Re: HELP HELP HELP HELP HELP!!!! (FrostyGSR)
ignitor! I have a spare one for sell 30.00 its yours
Old Apr 28, 2002 | 08:20 AM
KooK's Avatar
Mustang Sally
Default Re: HELP HELP HELP HELP HELP!!!! (RLukas)
try it again today... If you did get water on anything you shouldn't have than it should be gone by now (I hope). What did you cover your distributor with? Do you hear your fuel pump ingauging when you turn the key to the on posistion?
Old Apr 28, 2002 | 08:33 AM
New User
Default Re: HELP HELP HELP HELP HELP!!!! (Tapeworm)
Okay guys...here's an update.
I spent quite a bit of time last night troubleshooting it. I will hopefully fix it today.
When I pulled all my plugs out, it turned out that there was like an inch of fluid in each cylinder. I tasted some off the plug and I believe there was water in there. Granted, most was fuel, but there seems to have been water also. (I can't figure out how) So...I kept my plugs out and cranked the car for some time. This got most of the fluid out. It still wouldn't start. I decided to give it a rest and let it sit with the plugs out overnight.
I determined that I am indeed getting spark, unlike what I first thought.
One thing I considered is that I may have installed the distributor 180 degrees wrong. It is not supposed to be possible, but apparently it is, cuz I was able to. (Weird) This would have caused the plugs to be firing in the wrong order, and therefore make the cylinders flood. I didn't believe that it was possible to flood a Fuel Injected car, but then again, I'm special.
Any suggestions would be appreciated. Thanks for all your ideas so far.
Old Apr 28, 2002 | 08:56 AM
New User
Oh ****!!! Guess what? I just pulled off my valve cover. I found that my intake cam seems to have slipped a whole quarter of a turn. My exhaust cam is set to TDC, but my intake cam is at the 3rd cylinder position...That's no good. I guess I have a little project ahead of me. I have never taken my timing belt off, but is this all I need to do? I just need to slip it off and put it on correctly again, right? Someone with timing belt / cam gear experience please help.
Thanks for everything.
Old Apr 28, 2002 | 05:37 PM
New User
Update:
I fixed everything. I pulled off my timing belt and put the intake cam back where it belongs. I put everything back together and it started right up. I still haven't driven it, but I let it idle for like 15 min, and it's fine. I'm very happy that's all that was wrong.
Thanks everyone for your help.
Old Apr 28, 2002 | 05:44 PM
Jesse H's Avatar
Damn, how in the hell did u get the dizzy on 180 degrees wrong and have the cam slip like that?
The dizzy is keyed so it's just physically impossible. Nice that you got it running again.
Old Apr 28, 2002 | 07:16 PM
New User
Default Re: HELP HELP HELP HELP HELP!!!! (Jesse H)
Who the hell knows...both those things should have been physically impossible. I'm just special. I'm just happy it's fixed.
Old Apr 29, 2002 | 04:44 PM
SIK IN DA HED's Avatar
New User
thats good you found the problem and got it fixed.
Old Apr 29, 2002 | 05:11 PM
New User
Default Re: HELP HELP HELP HELP HELP!!!! (dlplayboy)
Sadly...another presented itself ONE day after fixing it. I now have a bad ignition system. damnit
Old Apr 29, 2002 | 05:58 PM
neo1z's Avatar
aftermarket ignition! i think that is awesome that you found that problem yourself, and fixed it. kudos!
9secg23eg
Nov 28, 2009 09:09 PM
italianhatch92
Apr 26, 2008 07:52 AM
jeezy
Oct 26, 2006 11:30 AM
0ptimus prime
Jun 8, 2003 02:51 PM
