help guys
Old Sep 6, 2011 | 10:39 AM
ek6's Avatar
ek6
Default help guys
b18c1 gsr motor :
sent my head off to get rebuilt and a skim so i put it back on hooked up all the lines changed intake to a blox racing one put the dizzy on set timing @tdc before i put the head on of course lined up cam gears set valve lash started car and engine is shaking idling @600
map sensor iat sensor iac sensor
and code 15 came up checked volts on map came back 5.0 volts on sensor
now i started it again and smoke came from throttle body nothing happening only smoke from throotle body every time car isn on the road as being turbod
i did compression test
cylinder 4 = 210 psi
3=210
2=210
1=175 !!!
Old Sep 6, 2011 | 12:36 PM
fcm's Avatar
fcm
Old Fart
Default Re: help guys
Recheck valve adjustments on cylinder 1. 94
Old Sep 6, 2011 | 12:50 PM
tonydize21's Avatar
Originally Posted by ek6
b18c1 gsr motor :
3=210
2=210
1=175 !!!
did you use a brand new head gasket?also check that you didnt swap the tps and the map sensor plugs,they are the same
Old Sep 6, 2011 | 01:41 PM
ek6's Avatar
ek6
bran new oem head gasket
ya ill check the valve lash again bud thanks really stubbed think i need new injectors as i started it there noe and injector for number 3 pissed out petrol this could affect why car is hard to start i cant even set ignition timing over these cel codes now
Old Sep 7, 2011 | 03:37 AM
ek6's Avatar
ek6
bump
Old Sep 7, 2011 | 04:04 PM
fcm's Avatar
fcm
Old Fart
Did you check the valve lash?
A leak down test on cylinder 1 is also in order. 94
nuginu
K Series
Aug 17, 2013 11:26 AM
grant97teg
Apr 20, 2009 06:47 AM
Pnoymugen
Apr 23, 2004 04:13 PM
dan89crxsi
Mar 1, 2004 03:03 PM
