Help!! got flatbedded home
Old Apr 2, 2003 | 04:04 PM
BrownGSR's Avatar
Default Help!! got flatbedded home
I was driving yesterday and my car started to sputter and then stalled when i came to a stop sign. It took a bit to turn over, I let it sit and idle(which was fine) When i pushed down the gas I kept on getting sputtering untill about 3k then it would rev fine. It seems like not enough fuel, or too much air, no spark, vacum? I have new wires (msd) and plugs (bosch +4) and a new fuel filter. What else could it be? I never changed the timing and I did replace the belt. No extreme motor work. Just started happening.
Old Apr 2, 2003 | 05:09 PM
UnionCity LS's Avatar
Default Re: Help!! got flatbedded home (matty1821)
yeah the same thing happens to my 87 jetta...i dont know either...Bump for a good question haha
Old Apr 2, 2003 | 06:22 PM
Tweakmeister's Avatar
bad gas?
check those wires too
Old Apr 2, 2003 | 06:28 PM
obsidianG35's Avatar
Maybe fuel pump? Could be anything.. did you check for any codes?
Old Apr 2, 2003 | 06:59 PM
cjohnson_2's Avatar
Default Re: Help!! got flatbedded home (r4integra)
Is it throwing any codes?
Old Apr 2, 2003 | 07:23 PM
romeo619romeo's Avatar
Default Re: Help!! got flatbedded home (cjohnson_2)
your timing prolyl went off... skiped a tooth
Old Apr 2, 2003 | 07:27 PM
SweetChin's Avatar
Default Re: Help!! got flatbedded home (romeo619romeo)
i says its probably the coil or ignitor in the distributor...i say test to see if your getting any spark..if you are then check to see if your getting fuel
Old Apr 2, 2003 | 08:11 PM
BrownGSR's Avatar
Its not throwing any codes, dont know if obd1 has anything to do with it. My boy said something about an air idel control valve, I never heard of it. Should i check my compression? Thanks for the help
Old Apr 2, 2003 | 09:03 PM
RedGSR's Avatar
could be timing belt
Old Apr 2, 2003 | 10:30 PM
natesgarage's Avatar
Default Re: Help!! got flatbedded home (RedGSR)
I seen real life situations with timing, the car does the exact same **** you just said. Have it checked by the people who installed your belt.
j_mee_5
Aug 17, 2010 09:47 AM
thanh4o8
Dec 10, 2009 11:28 AM
johnny090881
Jun 7, 2009 10:56 PM
manintux
Jul 7, 2008 05:52 PM
the soL that could
11
May 30, 2006 07:58 AM
