Help finding some part numbers please?
Old Oct 19, 2001 | 10:06 AM
hybrid8's Avatar
New User
Default Help finding some part numbers please?
I'm hoping someone that works at an Acura dealership or has access to part numbers in a shop manual can help me out. I need some part numbers for the parts I'll describe below.
They're all to fit a 1995 Integra GSR coupe, but the info should be able to be found by looking at the docs for any G3 Integra.
Thanks in advance for any help. I really appreciate it.
I've emailed 15 dealerships and none would give me the part numbers. I have a source for these parts, but unfortunately that person can't look them up visually, so they're not confident they'd get me the correct parts (and they can't return them once bought).
1. Left and Right metal brackets used to secure front nose onto car. (The nose/bumper has one of these pieces on each side near the top and they fit on the inside of the nose/bumper. I don't know what they're called, so I hope this description is enough. This part is most efinitely Integra-specific.)
2. Metal bolts with rubber washer used to hold the top of the nose/bumper to the body (the ones that go into the metal rail that sits on the top edge of the bumper). The Integra uses 9 of these I believe. The threaded section is very short (less than 1/2") and the head is thin, flat and a fairly large diameter (nearly 3/4"). They're the most noticeable fastener along the front when the hood is open.
3. Small black plastic/nylon round clips used to secure the rubber seal on the front lip of the hood. I think it uses 11 of them. These go through holes in the rubber seal and push up into holes on the bottom edge of the hood.
4. Plastic push-rivets (clips). Multiple used to hold the top of the rear plastic panel inside the Integra trunk. (A clip that opens when the center pin is pushed into it. These have a large 1/2 outer head with a push-piece that has a head about 1/8" or slightly larger. To remove these you push the center pin inwards. They aren't the same as the screw-ones that are used under the car and in some interior spots like the paneling around the rear windows on the hatchback)
5. Small screw-in clips. These are used for securing the skirts on the Integra and also used (3 per side) to hold the bottom of the trim around the rear windows in the hatchback models. Similar in function to the ones mentioned above, but to remove them you unscrew the center plastic screw.
6. Large screw-in clips. Similar to above but fatter (bigger screw and much fatter clip). Used under the car to hold the plastic guard that is part of the bumper and also used to hold the plastic wheel well liners to the fender. I have a part number for a replacement to these that doesn't use a screw (91512-SX0-003) - let me know if this is the new replacement part of if the screw--in ones are still available.
7. Blower resistor. 4-pin resistor coil that sits in the blower housing behind the glove box. Responsible for creating the three first fan speeds in the environmental control. Without the resistor you only have high speed (#4).
8. Instrument panel/environment control light bulbs. Small light bulbs used to illuminate fan controls (slider and button pictures) as well as the heater slider. Lights drop into hole in board and then turn to lock into place. Center environment control cluster takes at least 4 of these, two on the top for the buttons and two on the bottom for the sliders. I believe there may be no part number for these. I just found out they're commonly called NEO WEDGE lamps/bulbs.
Thanks for any help.
Bruno
Old Oct 19, 2001 | 09:58 PM
dc24me's Avatar
Default Re: Help finding some part numbers please? (hybrid8)
34354-SB0-003
Go to the parts counter and ask them to look it up on their database ask for the parts numbers and pricing. Everthing is on windows now...
1.8EG-T
Mar 31, 2014 11:21 AM
anthonyfa18
Feb 17, 2014 07:16 PM
aftCG
May 27, 2011 10:05 AM
oPEEPINGTOMo
Jun 23, 2008 03:41 PM
dc2long
Apr 20, 2008 09:07 AM
