Help!! Failed Emissions
Old Apr 3, 2006 | 07:25 PM
  #26
Jdmtuned's Avatar
From: Long Beach/Riverside, California, United States
I PASSED!!!!! changed the plugs, oil change and seafoam....so close to failing though i was actually at the MAX....but the number did drop a whole lot though from where they were before
Modified by Jdmtuned at 8:36 PM 4/3/2006
Old Apr 3, 2006 | 08:02 PM
  #27
TEST ONLY's Avatar
Default Re: (Jdmtuned)
Great!
Old Apr 9, 2006 | 07:18 PM
  #28
h8ted ek's Avatar
Default Re: (hazw8st)
hey jdmtuned. what was actually your procedure? changed spark plugs and and did seafoam. did you ride on your vtec hard or anything to get all that **** out. or was all that **** out just the seafoam and went straight for testing or Did you ride around for awhile and then did your emissions?
any info owuld happily appreicated. i should of pm ya instead.
Old Apr 9, 2006 | 08:51 PM
  #29
loudassVTEC's Avatar
Run Everwear's 3-step fuel system cleaner. You can get it done at any Tire Kingdom, Merchants, NTB. It works. Lowers emissions substantially, cleans your fuel tank, and lines, removes sludge and contaminants from your engine, restores compression, and restores a lot of power. At the same time it uses no alcohol products, so it won't hurt anything. It also removes any water from your fuel, and uses it to lower detonation levels. It is great stuff, and I wouldn't go with anything else. They did tests on four vehicles. Tested the emissions, and they all failed, and had a 22% power loss. It restored the power, and caused the emissions levels to drop to almost nothing!
Old Apr 12, 2006 | 07:21 PM
  #30
TEST ONLY's Avatar
Default Re: (loudassVTEC)
I have always ran Seafoam.....
Old Apr 12, 2006 | 09:15 PM
  #31
Jdmtuned's Avatar
Default Re: (H8ted Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H8ted Ek &raquo;</TD></TR><TR><TD CLASS="quote">hey jdmtuned. what was actually your procedure? changed spark plugs and and did seafoam. did you ride on your vtec hard or anything to get all that **** out. or was all that **** out just the seafoam and went straight for testing or Did you ride around for awhile and then did your emissions?
any info owuld happily appreicated. i should of pm ya instead.</TD></TR></TABLE>
I first ran the seafoam through the manifold, crankcase, and then some through the fuel tank, i drove it hard in vtec for about 4 miles, brought it back home and let it cool down. changed the oil and then the spark plugs, and i drove the car for about 120 mile so the code could clear from the ecu, and before i took the car to get it smog.... i let the cat warm up real good, the car barely pass because the number were actually at the max...
Old May 5, 2006 | 09:55 PM
  #32
Undercover_Skank's Avatar
good job buddy i told u to seafoam it from the start!
ElCivic89
Sep 13, 2013 11:14 AM
integra1990ls
Sep 23, 2008 08:32 AM
MugenDC4
Apr 12, 2008 10:34 AM
stilzx61
Jan 9, 2004 12:03 AM
