Help! DA replace thermostat?
Old Jan 23, 2006 | 04:42 PM
bxstylez's Avatar
Default Help! DA replace thermostat?
ok so when i warm up the car in the morning, i'll wait 5 minutes 'til the needle reaches the middle, engine warm
so i pull out and get on the highway and the water temp gauge needle will start moving back down to 'C'
after driving around for an hour or so, it'll stick to the middle between 'C' and 'H'
this has been happening for about a month
so a friend suggested i replace the thermostat?
would that be the only solution? i'm not looking to spend that much if i replace that part and come to find out its something else
he also said that i might be wasting gas if the ECU reads the temp as cold, engine cold; thus feeding more gas or what not (whatever that means), but yeah, i'm lost
any help would be appreciated
Old Jan 23, 2006 | 06:38 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Help! DA replace thermostat? (bxstylez)
a thermostat should only be like 10 bucks. might be the problem. i'd say it is too!
Old Jan 23, 2006 | 08:59 PM
HONDA_TYPE_R's Avatar
Default Re: Help! DA replace thermostat? (ohsnapzafingcu)
It may be stuck in the open position...your lucky if it is. I would rather have a thermo stuck open, than stuck closed. It's easy to replace the thermo, just drain the radiator, undo the lower radiator hose from the thermo, and then unbolt the thermo (8 or 10mm I believe). It takes about 10-45 minutes depending on your skill level.
Old Jan 23, 2006 | 09:41 PM
ZipTieGUy's Avatar
Default Re: Help! DA replace thermostat? (HONDA_TYPE_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA_TYPE_R &raquo;</TD></TR><TR><TD CLASS="quote">It may be stuck in the open position...your lucky if it is. I would rather have a thermo stuck open, than stuck closed. It's easy to replace the thermo, just drain the radiator, undo the lower radiator hose from the thermo, and then unbolt the thermo (8 or 10mm I believe). It takes about 10-45 minutes depending on your skill level.</TD></TR></TABLE>
im a newbie and even i did it. just loosen the plastic plug at the bottom to drain the coolant. you dont even need to remove any hoses. just undo 2-3 10mm bolts(they are hard to reach though) after that you stick a screwdriver pull that **** out and coolant will spill everywhere. then you just take it out put a new one in and refill collant in radiotor and your done.
Old Jan 12, 2009 | 03:09 PM
DAivnrocks's Avatar
What happens if the Thermostat is stuck closed cause I've been having problems with my temp readings too but my readings go up and and go back down everytime I excelerate and I was told it might be the thermostat
Turbotype
Sep 9, 2010 02:30 PM
litterbox
Mar 16, 2009 06:50 AM
Rob.
Oct 6, 2008 08:34 PM
johnwohl
Jan 30, 2008 01:15 PM
superstud
Oct 14, 2004 12:44 PM
