(help code p1337
Old Jul 28, 2005 | 02:40 PM
silver ek's Avatar
Default (help code p1337
where is the sensor at? some people it's by the oil pump ohers say in the dizzy?
i checked to see if it was pluged up n it's. i don't what else to do help...
Old Jul 28, 2005 | 04:03 PM
mastamind's Avatar
That code is for the crankshaft speed fluctuation sensor, right. Common sense would tell me that it should be located somewhere under the crank pulley.
Modified by mastamind at 7:08 AM 7/29/2005
Old Jul 28, 2005 | 07:17 PM
silver ek's Avatar
Default Re: (mastamind)
need more help. how i tell that's bad?
Old Aug 1, 2005 | 03:11 PM
BLUE EH3's Avatar
Help we my pennies
http://www.ff-squad.com/tech/w...g.jpg
Old Mar 9, 2006 | 12:26 PM
Katman's Avatar
Default Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ff-squad.com/tech/w...g.jpg</TD></TR></TABLE>
huh?
Old Mar 9, 2006 | 12:35 PM
b20integrapower's Avatar
Default Re: (Katman)
throwin same code cuz of my b20 swap..its located next to the crankshaft pully...b18b's have it and my b20 doesnt..so it throws a code
Old Mar 9, 2006 | 12:42 PM
Katman's Avatar
Default Re: (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">throwin same code cuz of my b20 swap..its located next to the crankshaft pully...b18b's have it and my b20 doesnt..so it throws a code</TD></TR></TABLE>
i take it you have a JDM B20 block?
there's a fix for tricking the CKF sensor which I borrowed from someone on here:
https://honda-tech.com/zerothread?id=1029958
"It is an easy way to disable (actually tricking the ecu not disabling it) the ckf sensor when swapping a non obd2 motor into an obd2 car. Just splice C1 to C4 at the ecu and c11 to c14 (not sure if this is necessary or not but I did it) and you are ready to go.
I came up with this idea when I realised that the CKF had 12 points at the crank and I was pretty sure the ckp was 24 at the cam on obd1 and 2 distributors. I searched to see if any one else had tried it and this is the closest post I found to anyone even thinking of it so I am posting it to save everyone else the trouble of swapping oil pumps. "
This will work when using a US OBD2 ecu as well.
Max713
11
Dec 11, 2008 03:48 PM
michael_c
May 2, 2007 05:59 AM
ensracer
Apr 2, 2004 06:22 AM
