need some help with brakes........
got some steel brake lines in, and i ran a search but didnt come across any for an eh2 steel break line conversion, can anyone lead me to some links with pics so i can do this? thanks
Re: need some help with brakes........ (gezer)
Pretty simple. There's a clip at the connection of each brake line to their perspective hardlines that needs to be removed. Then using a flare nut wrench (aka line wrench) unbolt the brake lines from the hardlines, unbolt the line from the caliper, and replace with your stainless steel ones.
Bleed the system afterwards and check for any leaks and you're good to go.
Location: centreville, Virginia, United States of America
open the line on the caliper your currently working on and have a buddy press the brakes slowly till brake fluid comes out in a stream. Rinse repeat for the other three calipers. There is a certain order your reccomended to do this in but i can't remember it off the top of my head.
Re: need some help with brakes........ (kelvar13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelvar13 »</TD></TR><TR><TD CLASS="quote">open the line on the caliper your currently working on and have a buddy press the brakes slowly till brake fluid comes out in a stream. Rinse repeat for the other three calipers. There is a certain order your reccomended to do this in but i can't remember it off the top of my head. </TD></TR></TABLE>
What you are doin there is getting any air out that may have snuck into the line while you had the hose away from the caliper/hard line. Air won't stop a car, atleast not in this type of brake set-up. Don't want to get them nice steel hoses on and end up in the rear end of someone...
Re: need some help with brakes........ (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">Some people go by farthest wheel from the master cylinder ie rr, lr, rf, lf.</TD></TR></TABLE>
That's what I was taught: farthest to nearest.
