Help! (._.')
Old Nov 24, 2011 | 12:15 PM
MissGs-r's Avatar
Icon2 Help! (._.')
I'm replacing shocks on my 01 Gs-r with
skunk2 sport shocks (part# 541-05-1010).
I'm really not too sure if I should cut the bump stops if I'm combining it with a Skunk2 Coil-over set I have.
And, missing stock damper mounting collar...is it absolutely necessary to have??
Old Nov 24, 2011 | 01:16 PM
RecklessEJ's Avatar
Default Re: Help! (._.')
yep i did on my buddys install and his ride was lowered nicely and wasnt bumpy at all no squeking either
Old Nov 24, 2011 | 08:19 PM
GagnarTheUnruly's Avatar
It depends on the drop you are expecting to have. You should definitely cut if you're going lower than stock, and how much to cut depends on how low you are going. You can always install the shocks and then see how much travel they will have at ride height.
I think installing the coilovers without all the recommended parts is a bad idea.
Old Nov 25, 2011 | 02:06 AM
MissGs-r's Avatar
Thanks, I ended up cutting the bump stops. And found the parts I needed for a complete install.Rides like a beau
mortificationrock
Nov 25, 2007 10:13 AM
shyboy817
Suspension & Brakes
22
Aug 25, 2005 11:30 AM
swifty4u
Jun 10, 2005 10:54 AM
DaChoZn1
Apr 8, 2005 11:41 AM
